Hi All,
I just tried to read the flash image from a Euro bug-eye 2002 WRX (Pr**rive PP)...
ECUExplorer reported it as a [AF531]... (no -7xxx)...
I was expecting the flash block connector to be the same 01 style as per my 01 WRX...
It looked like an 03 WRX 4 pin flash block... (I confirmed the appearance and wire colours since getting home as being 03 WRX style).
I didn't try to jumper the connector, as it isn't my car, and I wanted to double check before I stuffed some bits of wire in!
There was also a 4 pin black connector (long / thin ish) taped to the same bunch of wires (going to test connector and flash block). Does anyone know what this could be? - Sorry, I forgot to take my camera!
I couldn't read the flash using ECUFlash (but i'm still not sure whether or not it should read without the flash block connected).
Could it be that the flash block connector was changed before the end of the bug-eyes?
If the loom is this different (having extra pins doing things for this ECU), could it be that the ECU image may be incompatible with my 01 ECU - even if I can read it?
I guess I may get another opportunity to have a play with the car in a few days, so at least perhaps I should be able to grab the image.
I'm often hearing about people swapping ECU's between model years of WRX... Does anyone know roughly which ECUs are compatible with what model years?
