03 type flash block connector on an 02 WRX?
Postby JimbobUK » Sat Feb 11, 2006 6:34 am
Hi All,
I just tried to read the flash image from a Euro bug-eye 2002 WRX (Pr**rive PP)...
ECUExplorer reported it as a [AF531]... (no -7xxx)...
I was expecting the flash block connector to be the same 01 style as per my 01 WRX...
It looked like an 03 WRX 4 pin flash block... (I confirmed the appearance and wire colours since getting home as being 03 WRX style).
I didn't try to jumper the connector, as it isn't my car, and I wanted to double check before I stuffed some bits of wire in!
There was also a 4 pin black connector (long / thin ish) taped to the same bunch of wires (going to test connector and flash block). Does anyone know what this could be? - Sorry, I forgot to take my camera!
I couldn't read the flash using ECUFlash (but i'm still not sure whether or not it should read without the flash block connected).
Could it be that the flash block connector was changed before the end of the bug-eyes?
If the loom is this different (having extra pins doing things for this ECU), could it be that the ECU image may be incompatible with my 01 ECU - even if I can read it?
I guess I may get another opportunity to have a play with the car in a few days, so at least perhaps I should be able to grab the image.
I'm often hearing about people swapping ECU's between model years of WRX... Does anyone know roughly which ECUs are compatible with what model years?
JimbobUK
Postby wrx-blue-mica » Tue Nov 07, 2006 7:44 am
My WRX 02 Aussie version also has 4 pin flash connector.
I also having problem connecting ecuflash program to the ECU.
wrx-blue-mica
Postby crispyduck » Wed Nov 08, 2006 1:04 pm
JimbobUK,
Euro WRX's need the flash block connector shorted in order to read the ROM, see:
http://www.scoobypedia.co.uk/index.php/ ... gToYourECU
I can confirm this 100% on a Euro MY03 WRX and a Euro MY04 STi. I am 'confident' its the same on the MY02's also.
Note that due to the PPP the actual ECU ROM version reported may not reflect the actual model year of the vehicle. See my thread below for more info (post 6 & 7):
http://forums.openecu.org/viewtopic.php?t=965
Let us know how you get on.
Postby bendalyn » Thu Apr 12, 2007 2:18 pm
I have a MY02 STi UK and i'm worried that i can't read the ROM as it isn't listed...
I haven't tried yet either so i don't know if i can't for sure but, which file setup should i use - - MY02 WRX?
Thanks in advance,
bendalyn
Postby New2Scoobs » Sun Apr 15, 2007 11:03 am
bendalyn wrote:I have a MY02 STi UK and i'm worried that i can't read the ROM as it isn't listed...
Thanks in advance,
Yes, WRX02 - I recently pulled the rom from a friends STI MY02 with that.
Postby bendalyn » Mon Apr 16, 2007 7:00 am
To save me hunting through the forums (and still getting it wrong) procedure did you use?
I'm:
connecting open port
connecting green flash connectors
key on
press 'read ROM'
but all i get is a error message...
Cheers,
bendalyn
Postby New2Scoobs » Mon Apr 16, 2007 9:09 am
bendalyn wrote:To save me hunting through the forums (and still getting it wrong) procedure did you use?
I'm:
key on
press 'read ROM'
Cheers,
Have you jumpered the white block?
See section 4
Postby bendalyn » Wed Apr 18, 2007 7:06 am
i didn't think i needed to. Car is an STI UK and in the text is says that i don't need to do that:
"For all STi’s or any Drive-By-Wire (DBW) Impreza models that is all you need do."
I'm happy to try it though.. Am i likely to let the smoke out of my PCM?
Thanks,
bendalyn
Postby crispyduck » Wed Apr 18, 2007 12:28 pm
bendalyn wrote:i didn't think i needed to. Car is an STI UK and in the text is says that i don't need to do that:
Thanks,
I've just corrected my original Scoobypedia article. I needed to jumper my friends UK MY03 STi PP* to read the ROM. In the last 12 months or so playing and reading many articles I've never found anyone blow anything by correctly jumpering the flash block connector. I was just as worried as you in the beginning so know what your starting from. You wait until you flash your first ROM! Your heart is skipping a beat until it correctly starts when your finished. Now a reflash is like filling the car with petrol, only quicker!
Postby bendalyn » Wed Apr 18, 2007 12:34 pm
Uploaded my ROM this evening:
started openecu
selected read ROM
selected wrx2001-2003
connected green connectors
connected white jumper block
key on
'ok'
held breath
uploaded rom
cheers for your help
now where's that boost map...
bendalyn
