cboles wrote:* What market/model/year car do you have?
* What cable do you have? OpenPort 1.2? 1.0?
* What is your battery voltage? It might be low...
Sorry...USDM WRX Automatic...2002
Just ordered the Tactrix cable in the past 2 weeks...so 1.2 I guess?
It was battery voltage, I'm an idiot.
FWIW, flashing my ecu was MUCH easier than I ever anticipated, though figuring out injector scaling (I run ethanol) was a bit of a pain. I have modded stock injectors, that I previously had scaled to 760 on my UTEC (prior to me running ethanol). When I initially reflashed, I tried 760 again....SUPER lean, I ended up backing down to 580. I'm betting it is because of running ethanol instead of straight gas....anyways, once I got everything dialed in the car felt great....hopefully I can improve on my HP and 1/4 mile numbers now that everything seems to be working better.
