Thanks,
So the only thing that I will loose is the stuff that the ecu has learned like knock correction etc.
I will give it a try!
/L-O
cboles wrote:Perhaps there is something wrong with your paricular unit. Send me an email and we can work on resolving the situation. I have designed products in the past that used this chip that have had production quantities that are probably near a half million at this point, without the type of problem you are mentioning, so I don't think it is the chip in general. Most USB products I have designed these days don't use a chip like this because USB can be done inside the microcontroller, but I think it works well for this application.
west_minist wrote:cboles wrote:Perhaps there is something wrong with your paricular unit. Send me an email and we can work on resolving the situation. I have designed products in the past that used this chip that have had production quantities that are probably near a half million at this point, without the type of problem you are mentioning, so I don't think it is the chip in general. Most USB products I have designed these days don't use a chip like this because USB can be done inside the microcontroller, but I think it works well for this application.
I sent you an email on this with no reply.
Did you receive it? I resent one this morning.
My cable has gone back giving trouble.
Please advise me what to do.
