06 Lancer (South Asian Ver.)
Postby Zakie@TIC » Wed Jul 16, 2008 2:04 am
Hi, This BIN is off a 06 Auto Lancer, help with a XML file for tuning will be greatly appreciated.
Regards,
Zakie
Sri Lanka
Lancer-06(1600cc, South Asian Version).hex
(512 KiB) Downloaded 709 times
Zakie@TIC
Postby acamus » Wed Jul 16, 2008 9:57 am
here are the main maps.
85270000.xml
(1.55 KiB) Downloaded 745 times
acamus
Postby Zakie@TIC » Wed Jul 16, 2008 3:37 pm
Thanks Amacus, does anyone here have a complete XML for it, till then the rpm limiter will be very helpful.
Zakie@TIC
Postby acamus » Wed Jul 16, 2008 8:52 pm
here are the limits included, I bet nobody has disassembled this ROM, can you specify (HP, Tq, engine type) for this machine?
85270000.xml
(1.65 KiB) Downloaded 687 times
acamus
Postby Zakie@TIC » Thu Jul 17, 2008 7:43 am
Thanks for the limits, its a 1600cc 16v SOHC with a 4G18 motor pushing around 120HP/6000RPM and torgue 135NM at 4500RPM. Your XML should be great for a stock NA setup, can we go a lil bit further to see if we could play around a lil bit with parameters like injector sizing, MAF/MAP edit etc.8)
Zakie@TIC
Postby acamus » Fri Jul 18, 2008 5:17 am
4G18 does not have MAF sensor as far as i know.
Do you know the emission standard for it (EUROII\EUROIII\EUROIV)?
acamus
Postby Zakie@TIC » Fri Jul 18, 2008 10:24 am
Yes, its a Map sensor. Emission laws are still not strict in this part of the world, not sure for certain but at most it would be Euro 3 for the current models.
Zakie@TIC
Postby acamus » Wed Jul 23, 2008 10:47 pm
The RPM in fuel maps has 13 elements, sorry for the mistake, I keep interchanging B for D. Now they make sense.
acamus
Postby Zakie@TIC » Fri Jul 25, 2008 1:07 pm
So do you need to re do the XML?
Zakie@TIC
Postby acamus » Thu Jul 31, 2008 10:24 pm
Actually you needed to re-do the xml, here comes something more to your xml
85270000.xml
(7 KiB) Downloaded 722 times
acamus
Postby Zakie@TIC » Fri Aug 01, 2008 1:16 am
Looks great, will chk it out sometime, wonder if its safe to reflash the ecu with some changes to the map by selecting evo7/8 mode.
Regards,
Zakie@TIC
Postby Zakie@TIC » Fri Aug 15, 2008 3:23 am
Hello Acamus, I'm in need of a def file for the attached map, in the process I have messed up the previous map (Lancer asian ver.) as its not loading all the parameters like the timing stuff.
Regards,
Zakie
2004 Cedia.hex
(256 KiB) Downloaded 662 times
Zakie@TIC
Postby acamus » Fri Aug 15, 2008 9:59 am
Here it comes
99260003.xml
(1.56 KiB) Downloaded 672 times
acamus
Postby Zakie@TIC » Sat Aug 16, 2008 12:36 am
Thanks a Mil Amacus, I can read the fuel and Ignition maps with this xml, I'm getting some pics of the motor which I'll post shortly. This cars got a MAF sensor for sure and a 3 wire sensor which looks like Map sensor installed on the manifold. I'm trying to do a tune on a turbo build of a friend of mine who's unhappy with the current piggy back he's got
Zakie@TIC
Postby Zakie@TIC » Sat Aug 16, 2008 6:58 am
Here are the pics of the 2004 Asian Cedia motor, its 2.0 lt NA with a after market turbo installed.
Zakie@TIC
