2007 wrx reflash
2007 wrx reflash
Postby Aunti » Sat Mar 08, 2008 10:10 am
I'm trying to reflash my usdm 07 wrx to a stage 2 ots map i got. I'm using the open port 1.3 subaru tactrix cable and ecuflash 1.34 with updated defitions. So i connect the green connectors under steering wheel , run ecutek on pc connect tactrix cable turn key when prompted it reads the current ecu i have and save it to desktop as current.hex then i hit open new rom which is the ots map and it says :
UKNOWN ROM IMAGE
Ecuflash coud not recognize this rom using any of the current definitions. You can choose one of the following options:
Abort usint this rom image
Continue using this rom image with no defnition
Use wizard to create a new definition(not recommended!!!- for developers only)
if anyone could help me out thanks
Aunti
Postby Freon » Sat Mar 08, 2008 11:14 am
You should ask the source where you got that ROM.
Postby Aunti » Sat Mar 08, 2008 11:24 am
thanks for your reply, I posted there as well just thought I would try here in case someone had a similar problem.
Aunti
Postby Aunti » Sat Mar 08, 2008 3:09 pm
nevermind fixed my problem you can delete this thread now
Aunti
Postby Alex Maroto » Sat Apr 19, 2008 8:11 pm
Please help me, I had the same trouble, with a 2004 WRX...
I´m able to download map, but software says the same you got!!!
Help please
Where do I can get updated definitions files?
Alex Maroto
Postby 06STi » Sun Jul 27, 2008 11:21 pm
If you guys have ecutek on the cars ecu you need to get a delta dash with easyecu and have the stock rom reflashed back on to the ecu.
Once you have the stock rom reflashed back onto the ecu you can then tune the car or reflash with openecu or romraider
ecutek has a lock that your getting.
06STi
