Hello everyone!
Would like to activate LaunchControl at my JDM Evo7.
How can I do it?
Thanks a lot.
supaniga wrote:check you ecu to see if you have the cable for the clutch switch, this maybe the reason the limiter doesnt work, even if adjusted at the right address. I have a JDM 7, the car does not start without the clutch in but there is no wire on pin 43.
burgers wrote:Hi
I spent quite some time looking for the code for the stationary rev limit on the 98640014 ROM, also mrfred who has done much work on boost control, posted at evolutionm looked at the code and he also thinks this ROM does not have stationary rev limit.
MB
