I have reflashed my ecu w/ the following values...
Injector flow 600 cc..........at 800 and 700 were lean, close to 14.7
Latency Values Based off formula from
(((NewFlow/OldFlow) -1) / 2) + 1 = 1.44
http://forums.nasioc.com/forums/showthr ... +injectors
- Code: Select all
6.5 9.0 11.5 14.0 16.5
- Code: Select all
4.02 2.14 1.42 1.14 0.60
What direction do I need to go?
Damn how do I down load logs in csv. or period?
Basically, my stft is pegged t 21.00 at 4000 rpm in neutral and while cruising at 25.00 ......+- 3 at idle
