XPT stg2 91oct map
XPT stg2 91oct map
Postby DonArm » Thu Nov 23, 2006 4:13 pm
Does anyone have some experience with this map.
I bought it, flashed it to my ecu today and got some interesting logs :shock:
My first log run, I noticed that th IAM was already at 16, this is where it is set in the map. I went out did a few runs got home to check the data, looked at the min, max values before turning the car off and noticed that the IAM was down to 12 from 16. I also noticed that there was a -5 min value in the knock correction with a max of 15. I'm very concerned that there was some serious knock. I am running 93 oct. on this 91 oct. map.
I later found out that the blasted logging didn't work for some reason on the first run. I also noticed that my AFR did not get any richer than 12.0/1 with the XPT map.
Temp today was 75F, humidity about 65% I'm in Florida so pretty much at sea level.
I've attached the second run and one of my Cobb 93 oct stg 2 logs from a recent track event at Sebring.
Just comparing the logs it appears that the Cobb map is much better overall than the XPT map.
Some review and feedback from you guys would be greatly appreciated.
The mods on the car are as follows, TXS turboback exhaust, snorkle delete, K&N filter, P&P throttle body, gutted stock uppipe.
Additional info, the Cobb run was a 25 minute track session. The XPT run was a 3rd gear pull.
The car is used mostly for tracking.
Thanks for the input,
Don
PS I had to change the file extension to XLS since csv files aren't allowed attachments. Youcan probably change the file back to a csv after you download it to view it in ecuexplorer.
DonArm
Re: XPT stg2 91oct map
Postby ev8siv3 » Mon Nov 27, 2006 9:36 am
DonArm wrote:Does anyone have some experience with this map.
Don
Please message me on my forum. I will look at your logs, they will be nuked if posted in public. I've never seen results like what you speak of on 93 or 91 with the final map.
ev8siv3
Postby DonArm » Wed Dec 20, 2006 5:58 am
Braden,
I pm'd you the maps a couple of weeks ago and still have not heard anything back yet. Did you get the maps?
Don
DonArm
Postby ev8siv3 » Wed Dec 20, 2006 7:51 am
DonArm wrote:Braden,
Don
I belive i responded back a while ago, I'll go check again today.
ev8siv3
Postby DonArm » Wed Dec 20, 2006 5:49 pm
Sorry,
I meant the data logs that I sent.
Don
DonArm
Postby DonArm » Thu Dec 21, 2006 10:37 am
Interesting, I was hoping to get some feedback on this. After 247 looks I would have assumed that someone would give me some help.
DonArm
Postby ev8siv3 » Thu Dec 21, 2006 11:39 am
DonArm wrote:Interesting, I was hoping to get some feedback on this. After 247 looks I would have assumed that someone would give me some help.
Like I said before, look above, your datalogs are nuked. Don't look for help for MY products from any other site because they probably won't know what you're talking about =)
ev8siv3
Postby DonArm » Thu Dec 21, 2006 7:12 pm
As I said in the above post. I HAVE sent these data logs to you in a pm and received NO response.
These are only datalogging files NOT !! ROM images of Cobbs maps nor your maps. Again ONLY data logging files.
I don't think these are illegal to post.
Victor, why did you delete the logging data from the post?
Don (from Indy)
DonArm
Postby Freon » Fri Dec 22, 2006 10:59 am
Whoa, back up the bus. I didn't touch anything.
Postby ride5000 » Wed Dec 27, 2006 10:26 am
so where did the logs go?
ride5000
Postby Freon » Wed Dec 27, 2006 12:00 pm
I have deleted an only attachment once, and it just wipes it out with no trace that there was an attachment at all. It doesn't make the file zero bytes. I bet it just wasn't uploaded properly to begin with. Either that or Colby deleted it. Given what I know about how it works I think it just wasn't uploaded properly.
Postby DonArm » Tue Jan 02, 2007 2:26 am
Ok, sorry Victor.
DonArm
Postby knome » Tue Jan 30, 2007 11:21 pm
yea i was having those same problems, I also sent the data logs about a month ago and still nothing.
knome
Postby hakira » Tue Mar 27, 2007 10:56 pm
These maps are Base maps, maps where you plug in, Log, and adjust. If you got the free vers of the stg 2 then you should really street tune it from someone that understands tuning or get it dyno'd tuned. No 2 cars are exactly the same.
instead of making a gripe about not getting help, just read the tuning forums and learn. I learned a whole deal from reading all the tuning forums for WRX.
btw -kc is bad
that is prolly why your AM dropped. My guess is that the -kc was in high rpm under high load? cause thats where i got my -kc with the free osecurom stg 2 map
hakira
Postby ev8siv3 » Wed Mar 28, 2007 6:14 am
I've already been in contact, this is an old thread. Anyone with problems using the r1 of the XPT map for 02-05 can pm me their order number and I will send the new revision to them.
ev8siv3
