BobbyBigLug wrote:So is the 6 supported yet? Can I do an 8 ECU swap? Any help will be appreciated.
^ ^ ^ Nope, not yet.
Here's an on-going thread on swapping harnesses and using E7-E8 ECUs in E5-6s.
Link--> EcuFlash questions
Sanctifier wrote:BobbyBigLug wrote:So is the 6 supported yet? Can I do an 8 ECU swap? Any help will be appreciated.
Evodoc wrote:Sanctifier wrote:BobbyBigLug wrote:So is the 6 supported yet? Can I do an 8 ECU swap? Any help will be appreciated.
Bigbobby I searched today on my Evolution 6 RS2 and low and behold I did indeed find the white second connector under my dash board. You can use a USDM evo 8 or an evo 7 ecu, however there are a few things that you are going to have to do though.
cboles wrote:I spent some time with the H8 kernel today... it turns out that my assembler has some bugs and is generating incorrect opcodes for some instructions, which was causing the code to get wonky in strange places. I hope to get something out to people next week to try out the reading, and then do another release once the reflashing has been tested fully.
