Can someone look at my logs for STFT and help?
Postby WerdJack » Sat May 26, 2007 9:57 am
2002 wrx modded stock injectors flow tested at 840 cc 2 years ago.
I have reflashed my ecu w/ the following values...
Injector flow 600 cc..........at 800 and 700 were lean, close to 14.7
Latency Values Based off formula from
(((NewFlow/OldFlow) -1) / 2) + 1 = 1.44
http://forums.nasioc.com/forums/showthr ... +injectors
6.5     9.0     11.5      14.0    16.5
4.02    2.14   1.42     1.14     0.60
What direction do I need to go?
Damn how do I down load logs in csv. or period?
Basically, my stft is pegged t 21.00 at 4000 rpm in neutral and while cruising at 25.00 ......+- 3 at idle
enginuitylog_20070526_115022.xls
(0 Bytes) Downloaded 544 times
stft at 4000 rpm.txt
(2.13 KiB) Downloaded 556 times
stft at idle.txt
(1.65 KiB) Downloaded 545 times
WerdJack
Postby WerdJack » Sat May 26, 2007 10:29 am
let me try this one more time....
(24 KiB) Downloaded 329 times
WerdJack
Postby WerdJack » Sun May 27, 2007 8:43 am
OK so you have + stft values while cruising do I adjust my scaling or latency.
anybody?
WerdJack
Postby WerdJack » Sun May 27, 2007 2:15 pm
Disregard info above....when using UTEC make sure your scaling values match for example 650/650 versus 650/420 mine did not above....
WerdJack
