JECS ROM Download
Postby STi6 » Wed Apr 12, 2006 1:59 pm
No, these are all 99/00 model cars without AVCS
STi6
Postby richh » Wed Apr 12, 2006 2:02 pm
Eh? None of the JECS ECUs support AVCS West - this feature came in with the New Age cars, and of course this is the point at which Subaru switched to Denso.
richh
Postby STi6 » Wed Apr 12, 2006 2:06 pm
Some more ROM files, sorry if some are reposts but this should cover all ECU types from 99/00 models
ae802.bin
EURO/AUS/ZA
(128 KiB) Downloaded 1044 times
ae801.bin
EURO/AUS/ZA
(128 KiB) Downloaded 1003 times
ae800.bin
EURO/AUS/ZA
(128 KiB) Downloaded 955 times
STi6
Postby STi6 » Wed Apr 12, 2006 2:08 pm
And the JDM models...
af041.bin
JDM
(128 KiB) Downloaded 986 times
af040.bin
JDM
(128 KiB) Downloaded 962 times
STi6
Postby NoCtrl » Wed Apr 12, 2006 2:29 pm
richh wrote:Eh? None of the JECS ECUs support AVCS West - this feature came in with the New Age cars, and of course this is the point at which Subaru switched to Denso.
...,yes, the ECU switch.. ..there must be a story behind this..
AVCS should also have a history inside Subaru..?
And a reflashable ECU in 99/00 apears to me as early..
STI6: Thanks for the ECU-images :D
NoCtrl
Postby richh » Wed Apr 12, 2006 3:15 pm
NoCtrl wrote: ...,yes, the ECU switch.. ..there must be a story behind this..
No doubt, but it's probably a really boring story - likely to be along the lines that the control system parts supply contracts were up for renewal with the GD/GG, and Denso put in the best quote.
Not sure what you're trying to ask here chap. It's a given that FHI would have been researching it, given the potential advtages and also the fact that the likes of Honda had already shown it could be done in a cost-efficient and reliable package.
Again not quite sure what you're trying to say but again flash-MCU based engine control was becoming commonplace in the motor industry by the time Subaru went to it. I could be wrong, but I'm also under the impression that the US-driven OBD specs required flashable control units.
richh
Postby west_minist » Wed Apr 12, 2006 3:31 pm
My JECS Non-Turbo have AVCS. So as the models appearing the Legacies.
I think there tested out on the NA before introducing them 2 years later.
So, 99-01 for NA, then 01+ for turbo
I guess the same will be for the lift, which will most probably appear in 08+ turbo models.
Postby west_minist » Wed Apr 12, 2006 3:40 pm
STI6, you have any JDM STI ones?
You have access to the EcuTek pro?
Postby west_minist » Wed Apr 12, 2006 4:13 pm
Postby west_minist » Wed Apr 12, 2006 4:55 pm
Can anyone tell mewhat these numbers look like?
Postby Hitokiri » Wed Apr 12, 2006 9:12 pm
STI6!!!!! YESSSSSS!!!!
west - thats the fuel map
try scaling the data values with the following
14.7/(1 + (([value]-128))/128))
Postby Hitokiri » Wed Apr 12, 2006 11:02 pm
It is very interesting to note, looking at these maps that the P1 ecu shown seems to have the same main maps as the JDM 040 ecu.............
I was under the impression that prodrive had a special tune on their car, but it seems they just slapped the slightly more powerful JDM maps in there and called it a day.. verrrry interesting.
Postby Hitokiri » Wed Apr 12, 2006 11:22 pm
Interestingly enough these ecus all seem to use the same structure for storing major maps
here is the xml I have been using lately:
The load is still wrong - but otherwise most conversion seem ok. Its good for compairing fuel - timing - boost - wg tables though :)
   <ecu_struct id="xd" type="JECS ECU" include="" desc_size="#20000" reverse_bytes="True" file_name="99-00 jecs ecu.xml">
      <map name="Ignition Correction" type="3" active="1" help="" level="0">
         <rows count="16" func_2val="[value]" func_val2="[value]" offset="#0" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <cols count="16" func_2val="[value]" func_val2="[value]" offset="#0" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#41C" power="1" signed="False" format="%.2f" caption="" desc="Ignition degree" color_dir="0" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="Ignition Timing -Low Octane" type="3" active="1" help="" level="0">
         <rows count="16" func_2val="[value]*50" func_val2="[value]" offset="#835" power="1" signed="False" format="%.0f" caption="" desc="RPM"/>
         <cols count="16" func_2val="[value]/10" func_val2="[value]" offset="#820" power="1" signed="False" format="%.2f" caption="" desc="MAF Sensor Voltage"/>
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#71C" power="1" signed="False" format="%.0f" caption="" desc="" color_dir="0" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="?" type="2" active="1" help="" level="0">
         <rows count="16" func_2val="[value]*50" func_val2="[value]" offset="#8C0" power="1" signed="False" format="%.0f" caption="" desc=""/>
         <data func_2val="[value]" func_val2="[value]" offset="#8D0" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="?1" type="2" active="1" help="" level="0">
         <rows count="8" func_2val="[value]*50" func_val2="[value]" offset="#A7B" power="1" signed="False" format="%.0f" caption="" desc=""/>
         <data func_2val="[value]" func_val2="[value]" offset="#A84" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="012" type="3" active="1" help="" level="0">
         <rows count="8" func_2val="[value]*50" func_val2="[value]" offset="#CCC" power="1" signed="False" format="%.0f" caption="" desc="RPM"/>
         <cols count="8" func_2val="[value]/10" func_val2="[value]" offset="#CC4" power="1" reverse_bytes="False" signed="False" format="%.2f" caption="" desc=""/>
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#CD4" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="Fuel Map" type="3" active="1" help="" level="0">
         <rows count="16" func_2val="[value]*50" func_val2="[value]" offset="#137F" power="1" signed="False" format="%.0f" caption="" desc="RPM"/>
         <cols count="16" func_2val="[value]/10" func_val2="[value]" offset="#136F" power="1" signed="False" format="%.2f" caption="" desc="MAF Sensor Voltage"/>
         <data order="cr" func_2val="14.7/(1 + (([value]-128))/128))" func_val2="[value]" offset="#138F" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="??11" type="3" active="1" help="" level="0">
         <rows count="3" func_2val="[value]" func_val2="[value]" offset="#0" power="1" signed="False" format="%.0f" caption="" desc=""/>
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#25D2" power="1" signed="False" format="%.0f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>   <map name="Boost" type="3" active="1" help="" level="0">
         <rows count="8" func_2val="[value]*50" func_val2="[value]" offset="#1DF3" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <cols count="8" func_2val="[value]*100/169" func_val2="[value]" offset="#1DE2" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <data order="cr" func_2val="[value] - 94) * .15425" func_val2="[value]" offset="#1EC5" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="WG FF" type="3" active="1" help="" level="0">
         <rows count="8" func_2val="[value]*50" func_val2="[value]" offset="#1DFB" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <cols count="8" func_2val="[value]*100/169" func_val2="[value]" offset="#1DEA" power="1" signed="False" format="%.2f" caption="" desc=""/>
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#1F05" power="1" signed="False" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
      </map>
      <map name="Ignition Timing - High Octane" type="3" active="1" help="" level="0">
         <data order="cr" func_2val="[value]" func_val2="[value]" offset="#61C" power="1" signed="False" format="%.0f" caption="" desc="" color_dir="0" inc="1" incb="5" inc_dir="1"/>
      </map>
   </ecu_struct>
Postby STi6 » Thu Apr 13, 2006 12:24 am
They will all have the same structure. It will just be interesting to see how the maps differ, say from a AE802 (WRX) to a (JDM STi) AF001
STi6
Postby STi6 » Thu Apr 13, 2006 12:29 am
west_minist wrote:STI6, you have any JDM STI ones?
AFAIK the AF041 is a JDM STi, because thats the same ECU as in my car.
I dont have access to ECUTek unfortunately.
STi6
