Whats going on here?
Postby tode1 » Tue Apr 04, 2006 12:25 am
Hi iv obtained my fuel map on my Ecutek 3. Car is a 03 STi running Fp green, standard pinks/ walbro pump etc
why do I have two 0.02 engine load columns running the same target AFR's ???? Also, Shouldnt it be targetting stoich = 14.7 ?
Iv done some data logging and im getting negative knock correction at low revs, and then positive all the way up. My advance multiplier stays at 16 the whole way
tode1
Postby ev8siv3 » Tue Apr 04, 2006 8:23 am
You should be looking at your Timing Maps if you're getting knock at low rpms. Post that Map up, the fuel looks fine. When does that turbo kick in?
ev8siv3
Postby NeverLies » Tue Apr 04, 2006 10:31 am
Post your complete dump, will be easier for us to help you ;)
