Mitsubishi Evo flashing
Postby FrSTi » Mon Jan 30, 2006 8:54 am
Holy crap ! What the hell is that ?
Is this what we call "burned Rom" ? :lol:
FrSTi
Postby GTODesign » Mon Jan 30, 2006 9:24 am
Dude, thats a mess :shock:
I've contacted a distributor in china that actually has some surplus chips in stock, I'll check with them about the 7203 as well.
Everyone I've contacted over here (UK) have never heard of the thing.
GTODesign
Postby cboles » Mon Jan 30, 2006 1:53 pm
I don't think it is burned. I think the whole board was potted, and he has slowly been chipping away at it to expose the chips.
Postby GTODesign » Mon Jan 30, 2006 2:47 pm
Colby - How much work is involved in writing the kernel for the MH7202F chip and what information would be needed to do it? I haven't done any programming for years but I'm certainly prepared to pick it up again.
GTODesign
Postby cboles » Mon Jan 30, 2006 3:02 pm
First you need the chip datasheet.
If you are lucky, the ECU may use the same kernel loading protocol and the newer EVOs. If not, you may have to put the chip in a PROM mode and try to read it out with a PROM reader. This is a big pain. You will probably have to desolder a 200+ pin chip and build a socket adapter for it. After examining the ROM and disassembling it, you can figure out the kernel loading protocol.
From there, you go about writing a reflashing kernel which works according the the manufacturer specs. This is somewhat meticulous work, as a failed flashes can damage the chip or render them non-bootable without PROM or other boot-mode programming which may involve a lot of soldering.
Once you have those pieces working, you can start reflashing via the OBD port.
Postby GTODesign » Tue Jan 31, 2006 1:41 am
No problem, already working on finding a datasheet so I'll see where that gets me.
GTODesign
Postby GTODesign » Tue Jan 31, 2006 12:15 pm
Evo 4 PCB for reference...
Evo 4 PCB
GTODesign
Postby cboles » Tue Jan 31, 2006 12:22 pm
Could you get a close up of the CPU chip with the sticker/label on it? Can you remove the sticker+glue with mild solvent to see the part lettering on the chip below?
Postby GTODesign » Tue Jan 31, 2006 12:32 pm
E4 chip
Evo 4 chip closeup
GTODesign
Postby GTODesign » Tue Jan 31, 2006 12:37 pm
Under the label
MH6371F
ED04
76E56F-FFFB
JAPAN 6F1282
GTODesign
Postby wattsg » Mon Feb 13, 2006 9:41 pm
I've got an evo 5 - the board is out of the car as i'm currently running Motec - but i'll be able to experiment on people's behalf, or even lend the board if it's return is promised.
g.
wattsg
Postby wattsg » Wed Feb 15, 2006 5:08 am
Evo 5 PCB for reference - pardon the thumb
That's a 7202.
wattsg
Postby NeverLies » Wed Feb 15, 2006 10:57 am
Find attached datasheet for H8/534 and H8/536. No datasheet found yet for the others UC :S
hd6475368.zip
(1.02 MiB) Downloaded 607 times
Postby jaytech » Fri Mar 03, 2006 11:02 pm
GTODesign wrote:No worries. What vehicle is the MH7203 from?
The MH7203F is also found in the Mitsubishi Evolution 8/9 ACD ECU. Not sure in the 7, but should be the same.
jaytech
Postby GTODesign » Sat Mar 04, 2006 12:53 am
IIRC either the H8/534 or 536 is found in Nissan R33 RB25DET ECU's, has anyone done any work on these?
GTODesign
