by Freon » Wed Oct 04, 2006 6:52 pm
Wow, not sure what to say. I've been plugging away on mine for months.
I'd be extra careful before you turn the key off. Double check the log before you turn the key back from ignition on, because that's the "point of no return" so to speak. If you have any sort of flashing problem you can reboot your laptop completely, disconnect the cable, etc. and retry as long as you haven't touched the key.
Unfortunately I think the most useful tool would be the log from the last time you flashed the ECU, but you're not going to think to save it every time.
Where both on the same car? Different cars? Same exact model ECU? (AJ242, AJ243, etc)?
