EVO 6.5(TM) data
EVO 6.5(TM) data
Postby soondin » Sat Oct 21, 2006 1:13 am
It's a TM's stock data what I have
em2327.bin
(128 KiB) Downloaded 975 times
soondin
Postby HOK » Sun Oct 22, 2006 3:06 am
Thanks for the post!
Any change available?
HOK
Postby Fulcrum » Sat Dec 02, 2006 7:51 pm
Is that ECU with immo?
Fulcrum
Postby Evo4Mad » Sat Dec 02, 2006 9:18 pm
did you read this H8539F rom directly from the chip? or via your own kernal using the diagnostic port?
Postby Evo4Mad » Sat Dec 09, 2006 3:25 pm
can you provide an xml file for this?
replace stock ecu with EVO 8?
Postby red^shark » Mon Dec 11, 2006 10:38 am
Has anyone tried plugging in an EVO 8 ecu in place of the EVO 6?
Anyone want to try?
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0055568009
Red
red^shark
Postby S54fan » Mon Dec 11, 2006 11:49 am
Just had a look at this file in Ecuedit's hex editor and I see the following patterns/guesses: (addresses in hex, row lengths in decimal - a row in Ecuedit hex editor is like a load column in ECUflash).
Fuel map 18A9 row length 15
and 19bf
Timing 1df1 row length 19
and 1f61
20d1 length 19 one of those fuel mod maps with a lean spot in it not sure what they do?
2506, 251a, 252e duty cycle max 1/2/3 length 16
2542, 2556, 256a load targets 1/2/3 length 16
