07 STi
Postby akcel » Thu Oct 12, 2006 3:20 pm
wire boy....rom boy...make it happen. i might stop by tomorrow unless i get a dr's appt tomorrow.
akcel
Postby akcel » Thu Oct 12, 2006 9:18 pm
heres the image and a pic of the ecu case of keeners ecu
ecu case
Keener07STi.hex
(1 MiB) Downloaded 680 times
akcel
Postby ev8siv3 » Thu Oct 12, 2006 9:23 pm
Very interesting, the ROM code is in a new spot and in the original spot is wacky.
This is an A8DG300Z
ev8siv3
Postby Keener2.5 » Thu Oct 12, 2006 9:23 pm
Thanks craig!
Keener2.5
Postby akcel » Thu Oct 12, 2006 9:28 pm
no prob....maybe its an sti spec Z 2009!
akcel
Postby Keener2.5 » Thu Oct 12, 2006 9:36 pm
akcel wrote:no prob....maybe its an sti spec Z 2009!
Nope its the one and only Keener Special! One of a kind, you buy now!
Keener2.5
Postby akcel » Thu Oct 12, 2006 10:54 pm
wonder if ecutek has something goin on for this thing.
akcel
Postby merchgod » Fri Oct 13, 2006 7:19 am
This appears to be a rom from an 07 WRX or FXT, if I had to guess. It uses a lot of the 2x2 boost and wastegate maps that are common to those roms, whereas the multiple maps for the STi are usually the same size. And the A8... identifier also seems to be unique to the WRX and FXT (when looking at usdm cars from previous years). I'll look at adding this rom to the Enginuity's definitions once we determine which model it is from.
Some stats for this new rom:
total 2d maps: 502
total 3d maps: 128
total: 630
A2UG0007 (07 sti limited):
total 2d maps: 597
total 3d maps: 180
total: 777
merchgod
Postby Keener2.5 » Fri Oct 13, 2006 9:57 am
merchgod wrote:This appears to be a rom from an 07 WRX or FXT, if I had to guess. It uses a lot of the 2x2 boost and wastegate maps that are common to those roms, whereas the multiple maps for the STi are usually the same size. And the A8... identifier also seems to be unique to the WRX and FXT (when looking at usdm cars from previous years). I'll look at adding this rom to the Enginuity's definitions once we determine which model it is from.
total 2d maps: 502
total 3d maps: 128
total: 630
total 2d maps: 597
total 3d maps: 180
total: 777
Well its definetly an STi. It is a prototype from Japan, it has smog pumps (that I took out and am looking to turn off the code for), 06 wrx style injectors, still has a vf39 and came with a 6spd/dccd/brembos etc. Our guess over here is this is ECU is whats coming next. That being said, the motor only has like 70 miles on it right now, so I can't rev it out to see what it does. I really need to get the rom from the 07 vlimited I connected to the other day.
And once again, thank you guys for your help.
Keener2.5
Postby merchgod » Fri Oct 13, 2006 10:47 am
Keener2.5 wrote:Well its definetly an STi. It is a prototype from Japan, it has smog pumps (that I took out and am looking to turn off the code for), 06 wrx style injectors, still has a vf39 and came with a 6spd/dccd/brembos etc. Our guess over here is this is ECU is whats coming next. That being said, the motor only has like 70 miles on it right now, so I can't rev it out to see what it does. I really need to get the rom from the 07 vlimited I connected to the other day.
Ah, I was assuming it was USDM as I didn't read the whole thread very carefully. :oops:
I haven't seen a JDM 32bit sti rom yet, but the EDM 06 sti is similar to the 06 usdm wrx and fxt, so that would make sense.
merchgod
Postby Keener2.5 » Fri Oct 13, 2006 1:19 pm
merchgod wrote:Ah, I was assuming it was USDM as I didn't read the whole thread very carefully. :oops:
No no, let me clarify. It is a USDM STi. It just came directly from subaru of Japan to Fourstar Motorsports, then to me. Perphaps its EDM, but they don't do kilmeters do they? Any difference in the Canadian ECUs?
Keener2.5
Postby merchgod » Fri Oct 13, 2006 2:00 pm
Actually, this is an EDM ecu. If you look at 0x200c, you'll see EU. JDM would be JP. ADM would AU. And USDM would be US. Also you can clearly make out STi.
Also, if you look here, the AL340 is an 06 EDM STi:
http://www.ecutek.com/products/deltaecu/
The 06 EDM sti I've seen is A8DH200Z, but I don't know the case id for it.
merchgod
Postby Keener2.5 » Fri Oct 13, 2006 2:36 pm
merchgod wrote:Actually, this is an EDM ecu. If you look at 0x200c, you'll see EU. JDM would be JP. ADM would AU. And USDM would be US. Also you can clearly make out STi.
So is there any difference in the stock tune?
Keener2.5
Postby merchgod » Fri Oct 13, 2006 3:09 pm
Keener2.5 wrote:So is there any difference in the stock tune?
Looked at it closer and the all these tables were identical to a stock A8DH200Z (the known 06 EDM sti rom) - boost, initial WG duty, max WG duty, low detonation fuel, high detonation fuel, throttle actuator duty, base timing, ignition correction and AVCS.
The map offsets are different, but the number of tables, their order, their size are near identical to the A8DH200Z, meaning this is just another revision for this year. So, it is most likely an 06 EDM STi rom and definitely not an 07.
merchgod
Postby Keener2.5 » Fri Oct 13, 2006 6:37 pm
merchgod wrote:Looked at it closer and the all these tables were identical to a stock A8DH200Z (the known 06 EDM sti rom) - boost, initial WG duty, max WG duty, low detonation fuel, high detonation fuel, throttle actuator duty, base timing, ignition correction and AVCS.
That would explain the 06 STi label. :lol: Well the wiring is definitely 07, maybe the EDM is a year a head kind of thing, like japan is.
Edit: Would this also explain the lack of emissions equipment in the wiring?
Keener2.5
