Well, I tried the unlocking program. It didn't work but it did add a init sequence(FOFO) I will post the log. I also tried it on my work laptop, same thing happenes with both
In the unlocker it says its for ecuflash 1.8 would that be a problem, Im using 1.9?
Heres what happens without the unlocker running:
[00:23:21.093] Version 1.29.906
[00:23:21.109] 8 memory models read.
[00:23:22.062] 140 ROM metadata models read.
[00:23:22.062] checksum module "subarudbw" loaded.
[00:23:22.062] flashing tool "wrx02" loaded.
[00:23:22.062] flashing tool "wrx04" loaded.
[00:23:22.062] flashing tool "sti04" loaded.
[00:23:22.062] flashing tool "sti05" loaded.
[00:23:22.062] flashing tool "mitsukernel" loaded.
[00:23:22.062] flashing tool "mitsukernelocp" loaded.
[00:23:22.062] flashing tool "mitsubootloader" loaded.
[00:23:35.734] sending init sequence 1 (0001)
[00:23:38.968] sending init sequence 1 (0003)
[00:23:42.203] sending init sequence 1 (FFFF)
[00:23:44.921] no response to any known code
And here is what happend when I tried it with ecuunlocker running:
[00:01:02.375] Version 1.29.906
[00:01:02.375] 8 memory models read.
[00:01:03.437] 140 ROM metadata models read.
[00:01:03.437] checksum module "subarudbw" loaded.
[00:01:03.437] flashing tool "wrx02" loaded.
[00:01:03.437] flashing tool "wrx04" loaded.
[00:01:03.437] flashing tool "sti04" loaded.
[00:01:03.437] flashing tool "sti05" loaded.
[00:01:03.437] flashing tool "mitsukernel" loaded.
[00:01:03.437] flashing tool "mitsukernelocp" loaded.
[00:01:03.437] flashing tool "mitsubootloader" loaded.
[00:01:16.625] sending init sequence 1 (0001)
[00:01:19.859] sending init sequence 1 (0003)
[00:01:23.093] sending init sequence 1 (FFFF)
[00:01:26.343] sending init sequence 1 (F0F0)
[00:01:29.078] no response to any known code
notice the extra init sequence. Im happy it made a little progress but it seems far from working. Crazy stuff I wonder if the cable is messed up? I know it would be one in a hundred chances but I really dont think Im missing anything. Thx again for the help MJ
