Also, the latest build of my GT30 map. It is still very conservative.
AJ243 XML:
http://freon.shackspace.com/car/ecu%20a ... ZJ710J.XML
AJ243 ROM for my car:
http://freon.shackspace.com/car/ecu%20a ... 3-rev3.hex
edit 9-24-2006 new revision:
http://freon.shackspace.com/car/ecu%20a ... 3-rev4.hex
Factory AJ243 ROM (for comparing):
http://freon.shackspace.com/car/ecu%20a ... _AJ243.bin
Be warned it is still an ongoing development build of the ROM. Still only running about 18psi. I do think there is some interest in opening this map side by side with a stock map so you can see what kinds of things I have done, but I wouldn't recommend using it in your car. Particularly with my boost control solenoid, my boost control maps are rather violently different than you'll see elsewhere.
Relevent mods:
Perrin GT30 rotated mount turbo kit (T31 .82 AR turbine)
Perrin BigMAF intake
Tial 44mm external gate
Full 3" catless exhaust
ARO Premair 4-port boost control solenoid w/speed control
SSAutochrome front mount intercooler (24"x9"x3")
Stock BOV
Accomplished:
Extended map load ranges with reasonable values
Idles and cruises fine
AF in fuel maps is close to what I actually get per my wideband
MAF scaling reasonable
Relatively det/knock free map
Drivable every day
Spools up great
Still need to work on:
Actually running 20-22psi and pushing the loads the turbo is capable of
AVCS map needs lots of testing above 4800rpm
Still tweaking boost control a lot, tricky with 4 port solenoid
I didn't add any timing to the timing maps in the stock ranges, just extended. I think with the large turbo and front mount I could add some timing in the moderate load ranges
Engine bay
http://freon.shackspace.com/car/perring ... tdone1.jpg
Solenoid
