I am trying to find what offset my engine load is at. Can't find this anywhere unlike the IAM offset..
Or even can someone tell me what the acceptable values are? I am thinking 0 - 4?
If you have a 16bit ECU (pre-'06 WRX) the load values that you get from ecuExplorer would be
MAF*2*60/RPM
ahains wrote:My car had two addresses that gave reasonable value ranges, but were quite different from each other. Really to be safe you should calculate the load yourself and make sure it agrees with what you are seeing.
From another thread:If you have a 16bit ECU (pre-'06 WRX) the load values that you get from ecuExplorer would be
MAF*2*60/RPM
