Event Log :
Sunday 10th September 2006 - EvoScan v0.9 PreRelease version released.
By Default Logs are stored here:
C:\Program Files\EvoScan\EvoScan v0.9\SavedDataLogs\
Edit this XML file to change data item codes and calculations:
C:\Program Files\EvoScan\EvoScan v0.9\DataSettings\Data.xml
Data Logger Features: EvoScan v0.9
UPDATE:
1) Realtime Graphing support, mulitiple graph support, select data items.
2) Realtime playback of saved csv data log.
(even works without being plugged into the car!)
3) Create / Edit / Save / Load Gauge template xml files.
4) Drag, Drop, and Position any number of gauges onto the screen.
5) Assign data logging item to each gauge
6) Save/Load Gauge screen layouts/gauge config into a shareable xml file.
7) Simultaneous synced WideBand serialport meter Logging Support
- Innovate LM-1 Wideband support. (Tested as Working)
- Innovate LC-1 Wideband support. (Untested)
- AEM Uego wideband support. (Untested)
- Zeitronix Zt-2 Wideband support. (Untested)
9) Logging status colour indicator.
10) Added logger data items, Speed/Octane/AFRMap/MAP.
Data Logger Features: EvoScan v0.8
1) Increased Datalogging Speed!
- Added Log To File option
- Added Log To Screen option
- Added Logging SuperSpeed option
To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed!
2) Increased Stability of start/stop datalogger.
3) Added AYC Info to Data.xml
4) Added DTC Fault Code Info to Data.xml
5) New Log File Format! - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds
6) Altered DataItem Calculations:
- Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) )
- Fixed accuracy on Timing Adv calc.
- Added DataLog="Y" to xml file for default datalogging items ticked.
- Implemented Multiple ECUs to XML file.
7) Added DTC Trouble Code Support
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
Added simultaneous WideBand SerialPort Logging Support (untested)
9) Added View Log Files Menu Item
10) Added ABS Info to Data.xml
Register Now to Download EvoScan v0.9 - $25US
