Nissan with SH7055
Nissan with SH7055
Postby elecautocr » Mon Aug 28, 2006 3:10 pm
Hi members:
Do you know if it is possible with Tactrix cables and ECUreflash soft to readout and reflash the Nissan Sentra ECU ???
It has a mcu SH7055, Do I need a different software comunication to readout the Nissan ECU ??
Thanks for your attention
elecautocr
Postby radsdau » Wed Aug 30, 2006 3:45 pm
Can't say for sure, but I suspect it will be the same story as Subaru compared with Mitsubishi; the later ECUs share similar processors but different initialisation sequences, therefore not compatible.
If I were Mr Nissan I'd make it different from the others. But you never know.
Postby soondin » Fri Sep 29, 2006 12:56 am
Nissan's SH7055 protocol is very simmilar to Bosch and Siemens ECU.
If you make read and Write S/W. you have to break about Seed/Key process.
soondin
