ECUFlash unable to pull roms of JDM 03 STI's
Postby NeverLies » Wed Aug 23, 2006 4:11 am
Not sure it's only for safety purpose ;) Will see in IDA !
Postby west_minist » Wed Aug 23, 2006 5:03 am
To be honest it is.
Many people starts the car in gear :)
Postby ZuMBLe » Thu Aug 24, 2006 5:24 am
I get the same type of error message via ecuflash when I try to read my 05 USDM FXT. I know I can flash and read without using the clutch because I've done it with Street Tuner and the AccessPort.
ZuMBLe
Postby Easyrider » Sat Sep 23, 2006 1:28 pm
Anyone had any success with this "kernel get version" error?-as ive got exactly the same problem with a 2001 bugeye.
Easyrider
Postby m3n0ch3 » Sat Sep 23, 2006 4:48 pm
I have the same problem all the time with my 03 wrx...
what i do: open up ecuexplorer. turn it on.. wait for ecuexplorer to identify car... close ecuexplorer, open ecuflahs and there you go it works... dunno why tho..
m3n0ch3
Postby Easyrider » Sat Sep 23, 2006 9:59 pm
Explorer doesnt even work-allways says ECU disconnected
Easyrider
Postby Tuned by LIM » Sat Oct 14, 2006 8:53 am
Now I still unable to pull JDM STi 03 rom with ecuflash.
Tuned by LIM
Postby zigzagzok » Mon Oct 16, 2006 3:07 am
Tuned by LIM wrote:Now I still unable to pull JDM STi 03 rom with ecuflash.
same here , i have JDM 2.0 LGT Spec B 6MT
in ecuexplorer it does not "name the ecu" at all
it is a blank after col. expansion "+" sign
i can datalog with ecuexplorer though
in ecuflash i get the error msg below as well...
[00:08:46.757] Version 1.29.906
[00:08:46.767] 8 memory models read.
[00:08:49.661] 140 ROM metadata models read.
[00:08:49.661] checksum module "subarudbw" loaded.
[00:08:49.661] flashing tool "wrx02" loaded.
[00:08:49.661] flashing tool "wrx04" loaded.
[00:08:49.661] flashing tool "sti04" loaded.
[00:08:49.661] flashing tool "sti05" loaded.
[00:08:49.661] flashing tool "mitsukernel" loaded.
[00:08:49.661] flashing tool "mitsukernelocp" loaded.
[00:08:49.661] flashing tool "mitsubootloader" loaded.
[00:10:52.658] ssm2_init
[00:10:52.898] ssm2_init
[00:10:52.908] ssm2_init
[00:10:52.928] ssm2_init
[00:10:52.948] ssm2_init
[00:10:52.958] ssm2_init
[00:10:52.978] ssm2_init
[00:10:52.998] ssm2_init
[00:10:53.008] ssm2_init
[00:10:53.029] ssm2_init
[00:10:53.219] kernel get version
[00:10:53.539] validating denso kernel ram area addr: FFFF0000 len: 0008
zigzagzok
Postby zigzagzok » Tue Oct 17, 2006 2:19 am
hmm can anyone help?....
zigzagzok
Postby zigzagzok » Sat Oct 21, 2006 1:44 am
hi
have tried the following steps to pull the ROM from my '06 JDM 2.0 LGT 6MT
moved the comm ports from the default installation pt (ie com7) to com 9
tried both jacking up the baud rates and reducing the baud rates;
tried both the 2005-06 option and 2004 options for the DBW subaru
i still get the same error msg below - what cld be wrong? (the one that reads FFFF6000 was when i tried the 2004 DBW
can anyone help?
[00:11:59.124] Version 1.29.906
[00:11:59.124] 8 memory models read.
[00:12:00.375] 140 ROM metadata models read.
[00:12:00.375] checksum module "subarudbw" loaded.
[00:12:00.375] flashing tool "wrx02" loaded.
[00:12:00.375] flashing tool "wrx04" loaded.
[00:12:00.375] flashing tool "sti04" loaded.
[00:12:00.375] flashing tool "sti05" loaded.
[00:12:00.375] flashing tool "mitsukernel" loaded.
[00:12:00.375] flashing tool "mitsukernelocp" loaded.
[00:12:00.375] flashing tool "mitsubootloader" loaded.
[00:12:19.413] ssm2_init
[00:12:19.643] ssm2_init
[00:12:19.653] ssm2_init
[00:12:19.673] ssm2_init
[00:12:19.693] ssm2_init
[00:12:19.703] ssm2_init
[00:12:19.723] ssm2_init
[00:12:19.733] ssm2_init
[00:12:19.913] kernel get version
[00:12:20.434] validating denso kernel ram area addr: FFFF0000 len: 0008
[00:12:54.553] ssm2_init
[00:12:54.784] ssm2_init
[00:12:54.794] ssm2_init
[00:12:54.814] ssm2_init
[00:12:54.834] ssm2_init
[00:12:54.844] ssm2_init
[00:12:54.864] ssm2_init
[00:12:54.874] ssm2_init
[00:12:54.894] ssm2_init
[00:12:55.084] kernel get version
[00:12:55.605] validating denso kernel ram area addr: FFFF6000 len: 0008
[00:14:09.381] ssm2_init
[00:14:09.601] ssm2_init
[00:14:09.831] ssm2_init
[00:14:10.052] ssm2_init
[00:14:10.272] ssm2_init
[00:14:10.502] ssm2_init
[00:14:10.723] ssm2_init
[00:14:10.943] ssm2_init
[00:14:11.153] ssm2_init
[00:14:11.374] ssm2_init
[00:14:11.774] kernel get version
[00:14:12.305] validating denso kernel ram area addr: FFFF0000 len: 0008
zigzagzok
