EVO IX GT JDM 89280002
Postby Tuned by LIM » Mon Aug 07, 2006 10:17 am
Hi every one I'm newbie from Thailand.
I use 1.3M cable to download my ROM but I couldn't view any map.
My EVO9 GT 5M/T import from Japan 1/2006
Rom definition number was 89280002 seen by EcuFlash program.
Please help me with xml for my ECU version, thanks.
Here's my ROM file.
89280002.hex
EVO9 GT JDM2005 ROM image file
(512 KiB) Downloaded 1125 times
Last edited by Tuned by LIM on Thu Sep 07, 2006 10:34 am, edited 2 times in total.
Tuned by LIM
Postby Tuned by LIM » Wed Aug 16, 2006 2:08 am
:( anyone?
Tuned by LIM
Postby S54fan » Wed Aug 16, 2006 7:54 am
See your other post for XML file that also works for this ECU.
Postby S54fan » Wed Aug 16, 2006 8:03 am
You also have PM re immobiliser codes.
Postby Tuned by LIM » Fri Aug 18, 2006 11:16 am
Great , it's works. :D
now I can open for JDM ROM both of them, it's same definition code
Tuned by LIM
Postby S54fan » Fri Aug 18, 2006 1:44 pm
UK and JDM IX all seem to work on this definition.
Postby S54fan » Fri Aug 18, 2006 1:48 pm
I have no email address for you, so here I attach my tuned UK FQ340.
This is about as hard as you can be on Optimax whilst keeping it smooth and
not having excessive timing being pulled everywhere on a hot day in a high
gear.
1.75 bar peak, 1.65 bar held midrange, 1.6 at 5500, 1.55 at 6000, 1.45 at
7000, 1.4 at 7500 - using AVC-R.
AFR 11.6:1 midrange, 11.3:1 at the top.
Ignition and VVT are quite advanced over stock JDM. +3 degrees on ignition
on full load. Part throttle midrange areas retarded to remove lift off detonation.
3" turbo back exhaust, Walbro, HKS panel filter with airbox lid removed.
Changed maps: high octane ignition #2, high octane fuel, boost limit, lean
spool enable, lean spool disable, VVT.
EVO9 JM8857v15.hex
(512 KiB) Downloaded 1129 times
Postby turbocharged » Sat Aug 19, 2006 6:50 am
<table name="Injector size scaling" address="1107" scaling="Injector size"
I used to be able to able to read the value of '513' with the above address but ever since I upgraded to v1.28, using the same ROM and definition xml gives me a value of '2'. Does anyone have the same problem?
turbocharged
Postby S54fan » Sat Aug 19, 2006 7:51 am
Try 1106.
Postby turbocharged » Sat Aug 19, 2006 8:54 am
S54fan wrote:Try 1106.
1106 gives a value of '542'. But its strange that v1.27 gives the value of '513' @ 1107 while v1.28 gives the value of '2' @ 1107...this is on the same ROM! :?
turbocharged
Postby S54fan » Sat Aug 19, 2006 9:12 am
Maybe different scalings, I've had no need to change the injector values yet. But it makes sense that words would sit on even byte boundaries.
Postby evo400 » Sat Aug 19, 2006 11:24 am
S54fan wrote:I have no email address for you, so here I attach my tuned UK FQ340.
gear.
I am now using the GT timing as strating base and the car is now pretty more responsible.
Let me ask, how did you connected your AVC-R ? Do you use it in NO or NC mode ? I was trying to connect it on at COM-NO mode and i was not able to boost more than 1,5spike and 1,1at redline on 90%duty. I made a test, loaded conservative timing and choked the line to actuator, and boost has spiked to 2,1BAR, so i dont think i made some mistake instaling my AVC-R. All values on AVC-R looking good and realistic. Only last idea is taht my solenoid is not holding the boost in COM-NO mode and i should try the connection in COM-NC or try the tight test of the solenoid. Or may be some hardware solution like MBC will be easy and high functional too :D
Can you say us also if the VVT changes noticeable are for you?
And did you try to change the OPEN/CLOSED Look values ? I think i have too high EGT on closed loop going 100-120mph at very low throtle, my egt goes over 900°C
evo400
Postby S54fan » Sat Aug 19, 2006 11:56 am
AVC-R is COM-wastegate actuator and NO-compressor outlet.
"Can you say us also if the VVT changes noticeable are for you?"
Yes really helps spool up.
"And did you try to change the OPEN/CLOSED Look values ? I think i have too high EGT on closed loop going 100-120mph at very low throtle, my egt goes over 900°C"
No I didn't change them.
Postby evo400 » Sat Aug 19, 2006 12:44 pm
S54fan wrote:AVC-R is COM-wastegate actuator and NO-compressor outlet.
:oops: Oops i had it
COM - to turbo compressor outlet
NO - to wastegate actuator
This may be the my problem :oops:
http://www.apexi-usa.com/pdf/productDoc ... on/200.pdf
evo400
Postby tuning g » Thu Aug 24, 2006 6:14 pm
I opened the rom but can't understand anything any reason why it just looks scrambled
tuning g
