Stationary rev limit
Postby Hurrikain » Wed Aug 02, 2006 2:47 pm
Has anyone found the timing map for this? I have been forcing the LC to use a generated value in the normal timing maps, but something tells me that it is controlled in a different area. Ideas?
Hurrikain
Postby c-spec » Wed Aug 02, 2006 11:34 pm
huh ? what timing map for the stationary rev ?? i didn't even know it have a timing map. can you elaborate ?
c-spec
Postby Hurrikain » Fri Aug 04, 2006 6:06 pm
Well something is giving it a 20* range of timing between hitting the rev limit and recovering. I put -12* in at the same locations as my rev limit, for instance LC set at 5625 and I had it at 5500 and 6000. I placed it in the 100-140 load cell and went from 7-8 psi to 14psi. I tweaked the MIVEC a little and it seemd to like it. There is someone working on recoding the .bin for NTLS and a real stutterbox but we are awaiting assembly code for the newer type chipset (SH2 vs. HC11).
Hurrikain
Excellent question.
Postby mlr » Thu Aug 10, 2006 4:42 am
It's an important parameter - in some subaru maps they have it.
I see that the "stock" ignition retard on the limit is not enough -but i cant find the value:( I dont vant to spoil the map -as mentioned above...so we have to find this value.
mlr
