flashed again!
flashed again!
Postby 05GarnetLGT » Sat Jul 01, 2006 6:25 pm
this time, no ICM ROM error!
first impressions:
wtf? this isnt any faster?
its not hitting my target boost? at all?
any ideas?
05GarnetLGT
Re: flashed again!
Postby ev8siv3 » Sun Jul 02, 2006 7:32 pm
05GarnetLGT wrote:this time, no ICM ROM error!
first impressions:
any ideas?
Send me over your "new" rom, I have some new map editing software to try out and I can send u back a decent stage 1 I made for my buddies LGT.
ev8siv3
Postby Nuked » Sun Jul 02, 2006 7:46 pm
I would like this as well if possible?
Thanks,
Jason
Nuked
Re: flashed again!
Postby Hawk296 » Mon Jul 03, 2006 1:44 pm
first impressions:
any ideas?
ecupancakes had an issue like that on a baja.
Hawk296
Postby ev8siv3 » Mon Jul 03, 2006 2:29 pm
I emailed you the stage 1 map I made with some updates.
ev8siv3
Postby 05GarnetLGT » Tue Jul 04, 2006 9:48 pm
thanks, but unfortunately I wont be able to flash+datalog until next weekend...
05GarnetLGT
Re: flashed again!
Postby 05GarnetLGT » Tue Jul 04, 2006 9:49 pm
first impressions:
any ideas?
his issue was a WG duty cycle thing, my WG DC's were bouncing off of the maxes I set..
05GarnetLGT
Postby 05GarnetLGT » Fri Jul 07, 2006 6:59 pm
ok, tried out ev8siv3s stage 1,
first impressions:
holy crap this is responsive!
all that boost in the 35% throttle up is whats probably doin it
redlines at 7000 rpms, the throttle is really crisp.
BUUUUUT
I STILL cannot hit target boost. my WG DC values aren't hittin the maxes, and my boost wont go above ~13 psi. WTF?!
heres the logs if anybody is interested. note the targe maxboost is 2.1bar absolute, which is something like 16 psi.
ecuExplorer [AJ18B-6825] 07-07-2006 19h09m56s.rar
(22.62 KiB) Downloaded 429 times
05GarnetLGT
Postby ev8siv3 » Fri Jul 07, 2006 9:19 pm
05GarnetLGT wrote:ok, tried out ev8siv3s stage 1,
first impressions:
BUUUUUT
I didn't make too big of changes in the WG DC so that may be the reason that boost isn't targeting. I'm glad it feels good I'll check out this log tomorrow for you.
ev8siv3
Postby MDTURBO » Mon Jul 24, 2006 1:07 pm
how are you editing your files? I looked for an xmlwrite file so I could check out the download but no such luck.
MDTURBO
Postby MDTURBO » Mon Jul 24, 2006 1:16 pm
mehhh, i think i got it. had to run xmlwrite dos program first.
MDTURBO
Postby 05GarnetLGT » Mon Jul 24, 2006 7:40 pm
honestly, I'd use enginuity.
its much more aesthetically pleasing and ergonomic.
gl with tuning mdturbo.
(how much is the FMIC kit again?)
05GarnetLGT
Postby MDTURBO » Tue Jul 25, 2006 9:34 am
I have to get that program up and running first. It's written in java junk, but I'll give it a try.
FMIC are normally 1395 base , 1295 base for legacygt.com members 8)
http://marylandturbosolutions.com/catal ... ucts_id=32
MDTURBO
Postby MDTURBO » Tue Jul 25, 2006 9:54 am
had to install a newer version of java runtime to get it to work. It's a work in progress it seems.
Right now I'm primarily interested in turning off dtc codes, and enginuity doesn't show this ability. I think ecuEdit has DTC values, but there's no description. I imagine they're a bunch of 8 bit switches but no clue. Anybody figure out the turning on/off of DTCs?
MDTURBO
Postby 05GarnetLGT » Tue Jul 25, 2006 9:55 am
nah, but I will need to as im gonna see a p0204 soon from putting on a catless DP
05GarnetLGT
