c-spec wrote:hey Evo4mad when is the next release ?? this one the timing log is way off. thanks
july 3rd according to the web site
zlancerman wrote:Has someone figured out the correct formula for the Coolant Temp? My water temp gauge reads around 190, but the log has it at 260. Should I just change the formula from " + 308" to "+ 238"?
HxllxMan wrote:i'm waiting for the new release, hope it's for today and can't wait for it.
Evo4Mad wrote:Yep sounds good, I'll try the same on mine and see if is correct,zlancerman wrote:Has someone figured out the correct formula for the Coolant Temp? My water temp gauge reads around 190, but the log has it at 260. Should I just change the formula from " + 308" to "+ 238"?
Evo4Mad wrote:HxllxMan wrote:i'm waiting for the new release, hope it's for today and can't wait for it.
I am away on holiday at the moment - back tomorrow, I will have the rest of all week of my holiday to play with programming thisI will be emailing registered users an EvoScan v0.8 download link within the next 24hrs. Here is a preview of v0.8 new features:
UPDATE:
1) Increased Datalogging Speed! yay.
- Added Log To File option
- Added Log To Screen option
- Added Logging SuperSpeed option
To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed!
2) Increased Stability of start/stop datalogger, can now pull any plug anywhere and the program handles it perfectly, or cancel datalogging from any point of the process and it ends nicely.
3) Added AYC Info to Data.xml
4) Added DTC Fault Code Info to Data.xml
5) New Log File Format! yay. - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds
6) Altered DataItem Calculations:
- Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) )
- Fixed accuracy on Timing Adv calc. x-20
- Added DataLog="Y" to xml file for default datalogging items ticked.
- Implemented Multiple ECUs to XML file.
7) Added DTC Trouble Code Support
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
8 ) Added simultaneous WideBand SerialPort Logging Support (untested)
9) Added View Log Files Menu Item
Hitokiri wrote:I have a zeitronix WB as well as the rs232 packet info if you are thinking of integrating it.
