ECUFlash Map creation problem.
Postby nv-wrx » Wed Jun 14, 2006 10:03 am
Ok, I've looked around here for this specific problem and can't find anything.
I am running Ecu Flash V1.27on a laptop running Win2K. If I try to create a new map, the window comes up, I enter all of the data and then hit OK, but the map does not appear in the tree. Now here is the interesting part. If I go look in the .xml files -- the new entry is there... Then if I copy the .xml over to another computer everything works fine.
Any ideas?
Thanks,
Steve
nv-wrx
Postby nv-wrx » Thu Jun 15, 2006 7:39 am
OK to update this. I can't transfer any XML definition files from the computer I created it on to another computer... That kind of sucks. :(
No one else has experienced this problem?
nv-wrx
Postby nv-wrx » Mon Jun 19, 2006 1:33 pm
well, I did solve this problem. It appears that if I delete the 'level="x"' portion of the table tag, the map will then appear withing ECUFlash.
nv-wrx
