JDM EcuFlash
Postby iveytune » Thu Jun 01, 2006 6:59 pm
rev limiter 158C
Speed limit 158E
Boost cut delay timer 159A
Immobilizer 3ffce
Just to Add
Sean
iveytune
Postby burgers » Fri Jun 02, 2006 9:32 am
Hi iveytune
Thanks for those, I've added them to my xml file, attached on page one of ths thread.
MB
burgers
Postby RallyCam » Fri Jun 02, 2006 2:22 pm
My JDM Evo7 is the same 9864 id.
Posted image Here
You guys have obviously done a lot better than I have in finding these maps etc.
However, burgers, I'm not convinced that you are using the correct address for the axis.
For the Fuel Load scale you used the same address (4FDA) as you had for the Ignition (18 point vs 19 point scales), I used 4FDC for Fuel Load scale, and 503A for the ignition.
I'd be interested in your, and anyone elses thoughts on this.
I'll have a look over the rest of the values you have just posted sometime this weekend and see what I think.
Cheers
Cam
RallyCam
Postby burgers » Sat Jun 03, 2006 12:54 am
Hi Cam
You are spot on with the load scales for fuel & ignition. Thanks & please do double check all I've posted up, as this is the first map I've tried to do. I'm sure there will be more adjestments to make!
MB
burgers
Postby Ludikraut » Sun Jul 09, 2006 11:58 am
GTODesign wrote:... Load scale F $568E
I think the correct Load scale for the Fuel tables is at $5690 - 18 elements (at least for the Evo 7 Ralliart ECU that I've been looking at).
l8r)
Ludikraut
Postby salex » Sun Jul 30, 2006 2:33 am
Ludikraut wrote:I think the correct Load scale for the Fuel tables is at $5690 - 18 elements (at least for the Evo 7 Ralliart ECU that I've been looking at).
l8r)
True, same here (Evo7 93390000)...
GTO's addresses were very useful and accurate. But a few things need modifications here and there.
salex
