There are other tricks to reading out uncooperative ECUs...
- you need to wire things up inside the ECU to do it though. It can't simply be done over the OBDII interface. I have heard mixed reports of reading E*ut*k'd ECUs, so I think the additional security is something that was perhaps added recently. When was your car flashed?
cboles wrote:Who told you that EcuFlash would read EcuTek flashed STi ECUs? They may have changed the challenge response algorithm table or other things to render the standard initialization sequence inoperative. I would expect that you should be able to get a response to the SSM init request though...
Calvin told me that. So you're saying I can't read them no chance at all? Damn this sucks.
