S54fan wrote:Options... Port... OpenECU Mitsi 1.3 selected? (ie driver installed and cable found)?
Any DLL errors on starting ECUflash?
FQ340?
I've read a JDM GSR ECU on my IX FQ340. Wouldn't connect to my previously Ecutek'd ECU, and probably wouldn't connect to the original FQ340 ECU either since that has also been Ecutek'd. FQ300 or 320 should be OK I think as they should be the same as the GSR - will be interesting to compare.
galvitron wrote:I know that the FQ400 uses a Motec M800 OEM ECU. So do the FQ340's have the same??
S54fan wrote:I had a finger on the left mouse button and turned it on and within half a second clicked.
SilverBack wrote:Log actually says:
Sending init sequence 1 (0001)
Sending init sequence 1 (FFFF)
No response to any known code.
AutoXer wrote:SilverBack wrote:Log actually says:
That's the same thing that I get when I try to read my EcuTek'ed ECU. I have read succesfully from my 2nd ECU that I bought off of eBay.
SilverBack wrote:Opps, sorry missed this bit:
"I've read a JDM GSR ECU on my IX FQ340. Wouldn't connect to my previously Ecutek'd ECU, and probably wouldn't connect to the original FQ340 ECU either since that has also been Ecutek'd. FQ300 or 320 should be OK I think as they should be the same as the GSR - will be interesting to compare."
Cheers for the info.
"Evo VIII MR
FQ300/320-same as JDM GSR
FQ340-same ECU but with Unichip
FQ400-Motec M800 P&P locked
Evo IX
FQ340-Ecutek remap"
Saved me from taking the bugger out to have a look-see![]()
So if it is not the driver, not the ECU... what, dodgy cable? Idiot user?
There is an odd message about clicking OK quickly after switching on the ignition... prehaps I've been too slow...?
cboles wrote:There is no "flast click" issue with Mitsubishis - only some Subarus. The wire on the second connector for the Mitsubishi hard boots the processor in a different mode. It really doesn't matter what the ECU was doing before (including running the car).
"Evo VIII MR
Evo IX
FQ340-Ecutek remap"
