what about a "Mitsubishi EVO 4" category :)
Postby Evo4Mad » Tue May 02, 2006 12:20 am
Postby cboles » Tue May 02, 2006 12:36 am
Do you know how to read the ROMs from these? If so, sure!
Postby wattsg » Thu May 04, 2006 6:43 pm
I had a feeling the 4s were the same as 5s.
Do you have an Evo V ECU to play with Colby?
wattsg
Postby cboles » Thu May 04, 2006 6:46 pm
I think the 5/6 are the same. I don't know much about the 4. The 5/6 use H8/539 processors. I don't have a 5 ECU, but I have other Mitsubishi ECUs that are H8/539, so I should be able to get things running on those.
Postby Evo4Mad » Thu May 04, 2006 9:43 pm
Here are the Evo 4 ECU pics, is this the same as the evo5? what connections do you hook up to reprogram these chips, which chip is it that gets reprogrammed?
Postby Evo4Mad » Thu May 04, 2006 9:47 pm
closeups of evo4 chips
Postby cboles » Thu May 04, 2006 11:32 pm
I'd need to see what's written under the chip with a label. IIRC, it doesn't look like a H8/539.
Postby GTODesign » Fri May 05, 2006 1:27 am
We've been through this here ....... http://forums.openecu.org/viewtopic.php?t=266&start=0
The E4 ECU no where near the same as E5+, if anything it is more like E1-3 but with a MCu instead of EPROM/CPU. IIRC it is quite similar to 2G USDM Eclipse.
Thing is used E5 ECU's can be bought for less than GBP£50 and will plug straight into an E4 with a change of injectors so for the amount of development time involved I think everyones efforts would be much better spent on the later vehicles for now and anyone with an E4 that wants to do a reflash can simply use a later ECU.
GTODesign
Postby GTODesign » Fri May 05, 2006 1:29 am
cboles wrote:I'd need to see what's written under the chip with a label. IIRC, it doesn't look like a H8/539.
Just for reference...
Under the label
MH6371F
ED04
76E56F-FFFB
JAPAN 6F1282
GTODesign
Postby peluca » Fri May 05, 2006 5:52 am
I have access to EVO V, VI, VI.5 and VII. How can I help?
peluca
Postby Evo4Mad » Fri May 05, 2006 5:11 pm
yes I agree with you GTODesign, focus on the later vehicles for sure, I am most interested in the OBDII side of things, but if I can get a little guidance I might be able to progress the decompilation of the e4 ecu a bit of understanding by my own efforts :) since its the only ecu I have avail at the moment.
GTODesign wrote:We've been through this here ....... http://forums.openecu.org/viewtopic.php?t=266&start=0
Postby 20psi » Tue May 16, 2006 12:01 pm
hello, i just came across this awesome forum. Great work guys! I was wondering how soon support(dont know if thats the right wording or not) for the evo 5 ecus will be up. I have a evo 4 and from all the research I've done, the evo 5 ecu is a direct swap and reprogrammable , as opposed to the 4 one which is not programmable. I have access to purchase a 5 ecu and was wondering if thats what i should do or should I just wait a bit yet?
also what cable would i use?
thanks
-mike
20psi
Postby GTODesign » Wed May 17, 2006 2:02 am
I'm currently running an E7 ECU with a Ralliart flash in an E4. There's a few bugs to iron out and a bit of wiring to do but it's running.
GTODesign
Postby Evo4Mad » Wed May 17, 2006 4:08 am
Do you think you could help me with some heads up on whats required with wiring up an E7 ecu to my e4 too?
Postby 20psi » Wed May 17, 2006 4:45 am
wow thats interesting, i did not know that was possible. If you can run a 7 ecu, i suppose its possible to run a 8 ecu? Since I'm in the states, its much easier to aquire a 8 ecu. Has anyone else tried it? I know the 4 and 5 ecus are the same because I have the service manual and the pinouts are the same. I do not have a 7 or 8 manual so I have not compared them to my car yet. Very interested in what people have to say.
BTW how does the 7 ecu run in the 4, Big difference i bet!!
-mike
20psi
