by Hitokiri » Fri May 12, 2006 7:06 am
Its wierd. I install 1.26, and plug the cable in, then it asks me to install the cabel. I say install automatically, and it finds the correct drivers by itself. Installs. But it never installs a vertual serial port at all. If I plug the 1.3M in after that, no errors come up. Openport 1.3M pops up in the lower right as if it is installed and working correctly, but there is never a com port created in the ports section of device manager, ecuexplorer, ecuflash, etc.
I tried this on two computers, each of which had the same exact result. I then reverted back to the 1.0 cable and got the voltage errors shown below. Does it have something to do with using the 1.0 with drivers and software for the 1.3M??
Any ideas??
