ERROR WITH ECUFLASH123
Postby JRSCCivic98 » Tue May 02, 2006 5:15 am
cboles wrote:Similarly, there is really no harm in leaving the flash jumper connected, unless you think that you will go through all of the steps in EcuFlash to flash your ECU accidentally. I leave those connectors in my car all of the time. It is only the test mode connector you must connect / disconnect.
My personal preference is to leave the flash block off if I don't plan on flashing. That way if I accidentaly push the wrong button (hasn't happened yet) it won't accidentaly flash when I just want to read... that's all. In the end we all do what we want, I just wanted to make it clear above that the white block wasn't nessacery for the reading process... something a lot of newcomers aren't aware of.
Postby daddyhaw » Tue May 02, 2006 10:20 pm
Just ordered the jumped flash block connector from tactrix
I guess i have to try with that since i tried evrything else.
Will update when it arrives.
If that fails then I might ask somebody to remote connect to my laptop to assist.
BTW I appreciate all the responses so far
daddyhaw
Postby daddyhaw » Mon May 08, 2006 10:57 pm
Success at last.
I HAD TO use the connect the jumped FLASH BLOCK CONNECTOR.
Tried with and without and can say that definitely for my car AH581-5122 you have to jump the white connector to read the ECU
Spiider thanks for saying same , You are indeed correct sir.
Tuning time now!
daddyhaw
Postby Spiider » Tue May 09, 2006 3:39 am
I think more people are having trouble from NOT having it connected.
Not one person has reported accidentally flashing their car.
Glad to hear that it worked for you.
Postby JRSCCivic98 » Tue May 09, 2006 4:31 pm
That makes no sense... goes against everything that's been known about flashing procedures. I don't have to have my flash connector in to read... just to flash.
Postby cboles » Tue May 09, 2006 4:49 pm
Take a look at page 7 of this document.
On the 2004-2005 Impreza WRX, the "reflash" connector (B300) is actually a jumper for two signals. One is the reflash voltage, the other is an OEM line end (LE) signal line, which is used on 2001-2003 WRXs to enter the bootloader. There may be some 2003 models which use the newer connector, but still need the connection to this line. Or perhaps the ECU just likes to see that line being pulled to 12V. Just a thought.
MSA5T0418A112522.pdf
(724.89 KiB) Downloaded 638 times
Postby Spiider » Wed May 10, 2006 3:54 am
I have seen usdm 2003's with the two wire jumper, and some usdm 2003 with the older 2002 style single jumper. I think the switchover in harnesses was somewhere at the end of the 2003 model line.
It doesn't go against "goes against everything that's been known about flashing procedures", lol.
Postby JRSCCivic98 » Wed May 10, 2006 5:26 am
I've done successful reading without the white jumper on an 02 WRX as well as my 04... maybe you guys just aren't holding your mouth right. I will say this much... when I did do the 02 I was using the old "command line" ecuFlash... maybe something's changed in the new one?
