noob question re: 160kb vs 192kb
Postby ECUPancakes » Tue May 02, 2006 7:35 pm
Okay, I dumped (and posted) my A4SGE01C ROM, but it is 160kb. From searching around, I understand that ECUFlash does this in newer versions.
Am I able to flash this image straight back to the ECU? Or must I make it 192KB first? If I need to make it 192KB, how do I do this?
If I need to make it 192KB, why does ECUFlash save it as 160KB? Or did I do something wrong?
ECUPancakes
Postby NeverLies » Wed May 03, 2006 3:04 am
160k image does not contains the RAM area whereas 192K image do.
You can flash with 160K image.
In order to convert a 160K image to a 192K, you may use ECUEdit, there is an entry in the main menu to do this job ;)
Postby ECUPancakes » Wed May 03, 2006 10:56 am
Thanks. Is there any downside to flashing with the 160KB image? or does it work exactly the same.
ECUPancakes
Postby cboles » Wed May 03, 2006 12:03 pm
exactly the same. only smaller :wink:
