Need help for A4TE300D (UK WRX 05 - AJ830 8820) XML
Postby ECUboy » Sat Apr 08, 2006 1:01 pm
Is there any available for download? I'm idiot in creating xml.
ECUboy
Postby ECUboy » Sun Apr 16, 2006 8:56 am
Nobody knows how?
ECUboy
Postby qoncept » Sun Apr 16, 2006 4:56 pm
Subscribe.. I'm on my way out the door but I'll answer this later
Postby ECUboy » Mon Apr 17, 2006 8:13 am
Thank you. Waiting for you favourable response soon :D
ECUboy
Postby qoncept » Mon Apr 17, 2006 10:13 am
Ok, can you upload a copy of your rom? Do that and I should be able to take care of it..
Postby ECUboy » Mon Apr 17, 2006 11:09 am
I get it tomoro and will upload it
ECUboy
Postby qoncept » Mon Apr 17, 2006 11:16 am
Cool. tinywrex's XML write and Calvin's offsets should make it a pretty automated procedure. :)
Postby epifan » Mon Apr 17, 2006 11:41 am
qoncept wrote:Cool. tinywrex's XML write and Calvin's offsets should make it a pretty automated procedure. :)
xswrex (mb tinywrex) knows much more maps than Calvin post :lol: :lol: :lol:
epifan
Postby xswrex » Mon Apr 17, 2006 10:09 pm
here you go
A4TE300D.zip
(5.55 KiB) Downloaded 600 times
xswrex
Postby ECUboy » Sun Apr 23, 2006 12:11 am
Hi Guys,
I can't read my rom file using ecuflash or ecuedit. Attached is my rom file, appreciate your help.
**Encrypted attachment has been removed since it is of no use.
ECUboy
Postby ECUboy » Mon Apr 24, 2006 10:06 am
I cant use ecuflash or ecuedit to read the above attached rom.
Pls help, I wanna try to edit the maps.
Thks in advance.
ECUboy
Postby cboles » Mon Apr 24, 2006 10:33 am
the ROM is encrypted. it can't be read.
Postby ECUboy » Tue Apr 25, 2006 11:11 am
I will try manually dump from my ecu and upload here.
ECUboy
Postby ECUboy » Sun Apr 30, 2006 9:27 am
At last complete dumping my ECU as attached.
Had tried xmlwrite to create but doesn'y work well on ecuEdit. It does excellent in Enginuity!!!
I'm starting to edit the maps and test it out. Will post test result.
Thks for a wonderful forum and all GREAT developers.
ECUboy
