[edit] - made some UI improvements and fixed a problem with the '04 DBW reflash - now at rev 1.23
First, let me say that this is BETA software with insufficent testing by me - which is why I'm posting in hopes that I can get some people to test it out
http://forums.openecu.org/viewtopic.php?t=63
Playing with this ROM can serve as a good example of how to setup the ROM definitions as well as be a quick way to load something and try the editing features out.
Here are some of the editing features I have added in this version:
* user selectable color legends in the options menu
* cut and paste to Excel and between maps
* multiple selection using click, drag, ctrl-click, etc.
* cell highlighting to show changes from original ROM
* infinite undo / redo on a per map basis (might limit this in the future if memory becomes a problem)
* increment / decrement (amount is defined in the scalings)
* 1% increase / decrease (may have no effect if the display equation is too granular)
* set / add / multiply (you can actually enter arbitrary equations as a function of "d" at the "set" prompt - e.g. d="d*2+1")
* horizontal / vertical / 2-D interpolation
* revert selected area to original values
Please give it a try and let me know what you think...
