Shorting block connector..how?
Postby misguided_will » Mon Apr 10, 2006 5:22 am
hi all
i have a my03 Australian WRX.
i want to read and reset my ecu using a tactrix cable.
do i need to short the block connectors AND connect the green ones?
what do i use to short the block connectors?
i'm not an electronics person so something simple would be most helpful.
many thx
misguided_will
Re: Shorting block connector..how?
Postby ev8siv3 » Mon Apr 10, 2006 8:52 am
misguided_will wrote:hi all
many thx
I use 2 small pieces of wire. Cut, strip and stick it in there.
ev8siv3
Postby misguided_will » Mon Apr 10, 2006 2:07 pm
thanks champ.
will give that a try tonight.
misguided_will
Postby ECUPancakes » Sun Jun 25, 2006 4:40 pm
I've had good luck by using two uninsulated .250 crimp terminals attached to a single wire. This ensures a snug fit.
ECUPancakes
