Here is a ROM dump from a 2002 Stage 1 WRX running the High Wastegate Map to achieve target boost of approximately 14.5psi. I am working on the ECU Definitions file to allow more editing but haven't finalized a solid definition file yet.
Attached are the 160k and 192k versions. Use at your own risk.
** Will repost Later **
