Hi there
I read some info from FitFreak.net forum that there is a special driver for the openport 2.0 to work with the honda diagnostic system software and also the CM Update software.
I am interested to trick the ECU to read the wrong code and flash it to another calibration files. What are the tools I need? Where can I get the special driver to work with the CM Update software and how to trick it? What software to use to trick the ECU to read the wrong ECU model code?
Help needed. I hope the OpenPort 2.0 hardware and software will work and this is the thing I am looking for
