Initial IAM Value
Initial IAM Value
Postby Jeramie » Fri Mar 03, 2006 7:02 am
Not sure if this is the right forum (Couldn't really find one that fit). Just wondering if anyone knows how to change the ECU's initial IAM value? Thanks
Jeramie
Postby NeverLies » Fri Mar 03, 2006 8:32 am
You need to find the adress of this parameter in your ROM and no way to go except dissassembling ;)
Do you know the adress in RAM of IAM for your car ? If so, dissassemble your ROM with IDA and look for reference to this RAM adress, you should find quite fast the initial IAM parameter adress.
Postby Jeramie » Fri Mar 03, 2006 8:40 am
Good point. I dunno why I didn't think of that, I'll give it a try. Thanks for the input!
Jeramie
Postby Kha0S » Fri Mar 03, 2006 10:12 am
Jeramie wrote:Good point. I dunno why I didn't think of that, I'll give it a try. Thanks for the input!
Looks like the one for the A4SG900C is at 0x2A2AC... haven't tested it yet, though. :D
Kha0S
Postby NeverLies » Fri Mar 03, 2006 11:30 am
Right ;) If we use 0x20124 as IAM adress in RAM while monitoring (as laready published by some US users), we can find some routines managing IAM in the AF421 code like this one:
Postby Jeramie » Fri Mar 03, 2006 11:37 am
Wow you guys are quick.
To bad we don't have the same ecus :(
Hopefully I will get around to "trying" to take a look. IDApro is not exactly intuitive. :lol:
Jeramie
Postby Kha0S » Fri Mar 03, 2006 11:40 am
Jeramie wrote:Wow you guys are quick.
Jeramie --
What CalID are you running, and what's your IAM address?
I can pull it up in IDA and look for candidates for initial IAM.
Kha0S
Postby Jeramie » Fri Mar 03, 2006 11:53 am
Are you planning on testing?
Jeramie
Postby Jeramie » Fri Mar 03, 2006 11:58 am
Jeramie --
AH792
A4TF500F
http://forums.openecu.org/viewtopic.php?t=94
Thats my image.
IAM 0x020120
Thanks, I eperciate it!
Jeramie
Postby Kha0S » Fri Mar 03, 2006 12:58 pm
Looks like 0x2998D. Can't guarantee it, but try it out. Change it, flash, and pull IAM to see if it's changed.
Kha0S
Postby Jeramie » Fri Mar 03, 2006 1:04 pm
Cool, I'll give it a try and see what happens. Thanks for your help.
Heads up I sent you a PM.
Jeramie
Postby Jeramie » Sat Mar 04, 2006 8:57 am
I got a chance to edit the hex and flash the image and it work perfectly. 8) 8)
AH792
A4TF500F
Inital IAM Address = 0x2998D
Jeramie
