Successfully pulled G35/350Z BIN With Tactrix 1.3 Cable
Postby nosajton » Fri Aug 23, 2013 11:09 am
Hello guys, I have successfully downloaded and reflashed this bin to my ECU using a Tactrix 1.3 cable.
If anyone is able to make me a definition for this, I will release all the information about how to flash these vehicles... I need a definition though first! Any help would be appreciated
Jason
MYG35.BIN
(512 KiB) Downloaded 1591 times
nosajton
Re: Successfully pulled G35/350Z BIN With Tactrix 1.3 Cable
Postby nosajton » Sat Aug 24, 2013 10:19 am
Where did all the smart ecu hackers go? :(
Its a SH7055 Processor and the guys over at rom raider figured out the Calibration ID
ROM:00002040 a3mfed18n8: .sdata "3MFED18N8" ; DATA XREF: ROM:off_10BEC
ROM:00002040 ; ROM:off_11820
and checksum probably here
ROM:00000400 Check_dword_400:.data.l h'7AA746E1 ; DATA XREF: ROM:off_12AC
ROM:00000400 ; ROM:off_133C
ROM:00000404 Check_dword_404:.data.l h'55C2D3C9 ; DATA XREF: ROM:off_12A8
ROM:00000404 ; ROM:off_1338
We're so close to being able to tune nissans with openport! Any help would be appreciated.
I'm going to rom dump various other models over the weekend.
FYI the main fuel map on nissans is usually 8x8 and looks like this.
nosajton
Postby Mart » Tue Aug 27, 2013 1:40 pm
hence why COBB had an AccessPort for these vehicules...
Mart
Mart
Postby nosajton » Wed Aug 28, 2013 11:35 pm
Cobb stopped supporting them a long time ago. I'm trying to help the opensource community flash their nissans.
Anyhow heres a BIN I pulled off of a 2004 G35 5AT Ecu I just Purchased and plan to install in my car as these are newer and can be reflashed. the 2003 ecu seems it cannot support reflashing unless under SHboot
The JDM XDF reads the maps partially. things are a little off, if anyone out there can help me line this XDF up as I dont have the time, I'd be willing to shoot them some monies via paypal for their trouble.
The JDM 350z bin has a rom id offset at 3188 of 2WLGHD10
And my G35 ROMID is at 30D0 of: 3GIMBN06
So the map is a little off, the XDF shows around half the map on each table.
Hope you guys can help
Jason
2WLGHD10.xml
03 350Z XDF that reads the 04 tables but are a little skewed
(13.82 KiB) Downloaded 1530 times
2004-G35-AT-WAecu.bin
2004 G35 5AT
(512 KiB) Downloaded 1458 times
nosajton
Postby acmotor » Sun Oct 13, 2013 1:30 pm
Guys , i got Z350 2003 def . i think its very close to G350 ... send me your email
acmotor
Postby zswickliffe » Sat Nov 02, 2013 8:25 am
I've got a 2005 350z and I'm willing to help out in any way you guys need. I don't know much about tuning but definitely willing to learn.
zswickliffe
Postby acmotor » Sat Nov 02, 2013 2:00 pm
Hi guys , i managed to dig out somethin ... take a look
Nissan XML.jpg (136.86 KiB) Viewed 15432 times
acmotor
