i'm trying to save my rom so I can send it to a tuner; however, i'm having difficulty. Here's the log. It basically stops in the middle for some reason. any ideas?
i'm using the 2006+ CAN for Mitsu's. my car is a 2012 lancer gt n/a
[12:09:14.364] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:09:14.380] J2534 error [unable to open device].
[12:09:14.380] unable to connect to vehicle interface.
[12:09:14.380] interface close
[12:09:28.890] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:09:28.906] J2534 API Version: 04.04
[12:09:28.906] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:09:28.906] Device Firmware Version: 1.12.3688
[12:09:28.906] Device Serial Number: TAq63dbT
[12:09:41.438] -- loading kernel --
[12:09:41.438] -- connecting to kernel --
[12:09:41.438] kernel get version
[12:09:41.782] ECU HW part number : 1860B734
[12:09:41.797] ECU SW part number : 1860B73400
[12:09:41.828] -- unlocking ECU --
[12:09:41.828] starting session...
[12:09:41.844] requesting seed...
[12:09:46.853] interface close
[12:09:47.882] interface close
[12:09:56.240] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:10:01.279] J2534 error [ERR_TIMEOUT].
[12:10:01.279] unable to connect to vehicle interface.
[12:10:01.279] interface close
[12:10:29.015] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:10:29.047] J2534 API Version: 04.04
[12:10:29.047] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:10:29.047] Device Firmware Version: 1.12.3688
[12:10:29.047] Device Serial Number: TAq63dbT
[12:10:40.406] -- loading kernel --
[12:10:40.406] -- connecting to kernel --
[12:10:40.406] kernel get version
[12:10:40.749] ECU HW part number : 1860B734
[12:10:40.780] ECU SW part number : 1860B73400
[12:10:40.843] -- unlocking ECU --
[12:10:40.843] starting session...
[12:10:40.843] requesting seed...
[12:10:45.866] interface close
[12:10:46.895] interface close
[12:10:55.483] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:10:55.499] J2534 API Version: 04.04
[12:10:55.499] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:10:55.499] Device Firmware Version: 1.12.3688
[12:10:55.499] Device Serial Number: TAq63dbT
[12:11:08.785] -- loading kernel --
[12:11:08.785] -- connecting to kernel --
[12:11:08.785] kernel get version
[12:11:09.612] interface close
[12:11:09.643] interface close
[12:11:16.498] using metadata XML ID read_mitsum32186f8can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8can.xml
[12:11:16.529] J2534 API Version: 04.04
[12:11:16.529] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:11:16.529] Device Firmware Version: 1.12.3688
[12:11:16.529] Device Serial Number: TAq63dbT
[12:11:21.642] -- loading kernel --
[12:11:21.642] -- connecting to kernel --
[12:11:21.642] kernel get version
[12:11:21.970] ECU HW part number : 1860B734
[12:11:21.986] ECU SW part number : 1860B73400
[12:11:22.017] -- unlocking ECU --
[12:11:22.017] starting session...
[12:11:22.017] requesting seed...
[12:11:22.032] sending key...
[12:11:22.360] -- uploading kernel --
[12:11:22.376] .
[12:11:22.391] .
[12:11:22.407] .
[12:11:22.422] .
[12:11:22.438] .
[12:11:22.438] .
[12:11:22.454] .
[12:11:22.469] .
[12:11:22.485] .
[12:11:22.500] .
[12:11:22.516] .
[12:11:22.516] .
[12:11:22.532] .
[12:11:22.547] .
[12:11:22.563] .
[12:11:22.578] .
[12:11:22.578] .
[12:11:22.594] .
[12:11:22.610] .
[12:11:22.625] .
[12:11:22.625] .
[12:11:22.625] -- connecting to kernel --
[12:11:22.625] kernel get version
[12:11:22.641] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[12:11:22.641] reading kernel comm buffer size
[12:11:22.641] comm buffer size set to 1024
[12:11:22.641] reading kernel flash buffer size
[12:11:22.641] flash buffer size set to 4096
[12:11:22.656] -- dumping ECU memory --
[12:11:22.672] kernel read area: addr: 00000000 len: 0400
[12:11:22.719] kernel read area: addr: 00000400 len: 0400
[12:11:22.766] kernel read area: addr: 00000800 len: 0400
[12:11:22.797] invalid / no kernel response to read
[12:11:22.812] kernel read area: addr: 00000800 len: 0400
[12:11:22.844] invalid / no kernel response to read
[12:11:22.844] kernel read area: addr: 00000800 len: 0400
[12:11:22.890] invalid / no kernel response to read
[12:11:22.890] ECU memory read failure.
[12:11:22.890] can't read image.
