3000gt ecu re-clock data logging
Postby 92-stealth-13g » Sun Oct 07, 2012 4:05 pm
Trying to figure out how to get my data logger working with my raised rev limiter ecu. I have gotten a new software version so I can make my own re-clock % up to 5 figures, example 10.338% Problem is my logger still won't communicate. It works when I put the stock crystal in but not when I "chip" it. Here is what I am working off. I was told the stock ecu crystal is 10.01mhz
I tried 11.0592mhz, 8,065rpm, this what is most often used. It equates to 10.4815184815185% (if the stock crystal is 10.01mhz) I tried putting in 10.48x% numbers but it won't communicate. Do I need to be able to put the whole 10.4815184815185% into the data logger re-clock? Any ideas on where to go from here? Thanks.
92-stealth-13g
