definitions request 08 wrx
Postby Chris250 » Wed Mar 28, 2012 12:34 pm
Does anyone have a definition for ECU AZ1E400U 5142584007?????
Chris250
Re: definitions request 08 wrx
Postby Chris250 » Thu Mar 29, 2012 4:00 am
just found out that these Impreza's were recalled in the UK and prodrive used ECUTEK to remap them hence locking them
Chris250
Postby Wiretap » Sat May 05, 2012 12:58 pm
You'd need to post the ROM if you wanted a definiton, but it turns out there already is one available :)
Wiretap
Postby Walter » Sat May 05, 2012 1:20 pm
Wiretap wrote:You'd need to post the ROM if you wanted a definiton, but it turns out there already is one available :)
are sure its available there??
Walter
Postby Wiretap » Sat May 05, 2012 1:30 pm
http://www.romraider.com/Documentation/SupportedECUs It's on this page
I managed to open it in RomRaider but not ECUFlash, so a flash-method definition would need to be created. Which flash method did you use to read the ROM?
Wiretap
Postby Chris250 » Thu Jun 28, 2012 8:31 am
I used ECU flash, the strange thing is I could read a 2010 no problem
Chris250
Postby Jochen_145 » Fri Jun 29, 2012 4:03 am
If it is really ECUtek, the seed-and-key prozedure has been chanced, so of ECUflash will not read and wirte.
It is done because of read-protection.
If you want to remap this ecu, you firstly have to recover the ecu via SHbootmode to stock and than you can use ECUflash again
Jochen_145
