Honda ecus
Honda ecus
Postby qoncept » Wed Feb 22, 2006 11:37 am
I'm not sure what all is involved, but is there any chance of dumping/flashing Hondas any time soon, Colby? It seems that the guys on pgmfi.org are afraid of anything after OBD-I for some reason, and I'd really like to be able to tune my buddy's RSX.
I've looked around with the little free time I've had lately, and I haven't found anything yet.
Postby cboles » Wed Feb 22, 2006 2:33 pm
Do you know what CPU is used in the Honda ECU you are interested in?
Postby qoncept » Thu Feb 23, 2006 7:43 am
Let me see what I can dig up..
Postby qoncept » Thu Feb 23, 2006 9:04 am
Alright, I'm going to have to get at the ECU.. what do I need to get pictures of to help?
Postby NeverLies » Thu Feb 23, 2006 11:59 am
Have you looked here : http://forum.pgmfi.org/ ? You can find a lot of informations for Honda cars ;)
Postby qoncept » Thu Feb 23, 2006 1:01 pm
Neverlies, yeah, but like I said.. it seems they are afraid of OBD-II. When it came out, they just started taking the ECUs out and putting their old chipped OBD-I ECUs in them. And now with the K series they, apparantly, just haven't done anything. And the only info they have on the wiki about the RSX is the oz type r.
I'm looking forward to playing with their 3D (4D?) maps, though. I think Hondata is the only thing they can tune them with for the moment.
All I know right know is that the engine in the 2002 type S is a K20A2. We're going to meet up this weekend and pull the ECU out and see what we find.
Postby cboles » Thu Feb 23, 2006 1:07 pm
Take good closeup pictures of everything. Useful things to know that help identify the chips:
* The exact part number text on top of the chips (may need to remove clear coatings to see properly). Sometime the chips are embossed, and it is very easy to read the text if you put a piece of scotch tape over the chip.
* The chip package shape (pictures are sufficient)
* The pin count of the chips. Often this is written on the PCB silkscreen.
* What pin numbers the crystals and power supply / ground lines are connected to.
Postby jaytech » Thu Feb 23, 2006 11:36 pm
Usually Honda ECU's use OKI microcontrollers, not sure what the newer ones use.
jaytech
Postby qoncept » Sat Feb 25, 2006 9:13 am
Alright Colby, here's the best we could get..
The main CPU has 144pins and the following printed on it:
645
0KI JAPAN
L660592
147225362
I'm not sure exactly what else you need, so let me know if I'm missing anything important. I don't know what the crystals you're talking about are, and I'm also not sure where the power source is grounded.
Postby qoncept » Sun Feb 26, 2006 8:13 am
Hmm.. yep. I thought about it this morning and thought I might have forgotten to attach the image..
It's not that great, but I can answer questions if you have any.
Postby cboles » Mon Feb 27, 2006 8:43 am
My guess is that it is an OKI ML66Q592. Here is the datasheet. It would be nice to look at a lot of Honda ECUs to see how much the processor they use varies from car to car and year to year.
ml66592_ml66q592.pdf
OKI ML66592 CPU datasheet
(114.45 KiB) Downloaded 1805 times
Postby cboles » Mon Feb 27, 2006 8:55 am
towards the bottom of this doc, you can see some of the other CPUs honda has used:
 OBD      ID   Market      ECU         Car/Engine         notes
 OBD1   A6   JDM      P13-J00/J50      93-95 Prelude H22A      (4 plug => ABS)
 OBD1   A8   OzDM      P14-Q00      93-95 Prelude Si H23A   4WS
 OBD1   A9   ?      P12-A00   ?
 OBD3   A61  OzDM      PLR-Q71      Civic          66q591 KS, PA, immo?
 OBD1   B9   JDM      P39-N50      92-95 Accord SOHC VTEC  66911
 OBD1   C0   OzDM      P14-Q00      93-95 Prelude Si H23A
 OBD1   C1   ?      P12-A00   ?
 OBD1   D2   JDM      PT6-J50      Accord
 OBD1   D5   OzDM      P0A-Q00/Q50      94-95 Accord Ex      66911
 OBD1   D8   OzDM      P0C-Q00      Accord Exi F22B      66911
 OBD1   E4   OzDM      P14-Q52      93-95 Prelude Si H23A
 OBD1   E6   JDM      P13-N01      93-95 Prelude H22A
 OBD1   L3   OzDM      P0C-Q10      Accord Exi F22B      66911, immo
 OBD1   S40  JDM      P0F-902      Accord 95 CB5 H22a      Hitachi
 OBD0   10   JDM      PK2-0133      Prelude 90-91
 OBD0   27   OzDM      PK2-6220      Prelude 90-91
 OBD0   45   JDM      PM7-E04      CRX 88-89
 OBD0   50   JDM/EDM      PM7-9040/0330   CRX Si 89-
 OBD0   51   JDM      PK2         Prelude 90-91
 OBD0   54   OzDM      PR4-Q02      90-91 Integra LS/GS B18a
 OBD0   53   USDM      PK2-6660      Prelude 90-91
 OBD0   58   JDM      PR3-901      89-91 B16A EF8/9
 OBD0   59   JDM      PR5-003      90-91 Integra ZXi (1.6 sohc)
 OBD0   65   USDM/CDM   PM6-A09/C00      CRX 90-91
 OBD0   71   JDM      PW0-000      CRX SiR 89-91
 OBD1   83   OzDM      PT3-Q50      Accord
 OBD0   92   OzDM      PR4-Q60      90-91 Integra LS/GS B18a
 OBD0   93   JDM      PR3-900      89-91 B16A DA6
 OBD1   97   OzDM      PT6-Q50      Accord
 OBD0   120   JDM      PM7-Q020      CRX 88-89
 OBD0   121   EDM      PM7-E020      CRX 88-89
 OBD1   202   JDM      P29-900/000      Civic D16A ZC DOHC      OBD1 ZC
 OBD1   203   JDM      P30         Civic B16A DOHC Vtec      common dev rom
 OBD1   204   JDM      P54-900      Domani B18B DOHC
 OBD1   205   JDM      PR3-J01      92-93 Integra XSi B16A    no inj test, no PA, yes knock PR3-J01
 OBD1   206   JDM      P08-020      D15B SOHC Vtec
 OBD1   208   EDM      P28-G00/G50      SOHC VTec
 OBD1   209   EDM      P30         Civic B16A DOHC Vtec
 OBD1   211   USDM      P07         Civic VX D15Z1 Sohc Vtec-E   5wire o2
 OBD1   214   USDM      P74         Integra B18
 OBD1   215   USDM      P61         Integra B17A DOHC Vtec
 OBD0   216   USDM      PM5/PM9      D15B DPFI   only 90-91
 OBD1   218   JDM      P07-G01      Civic SOHC Vtec-E 1500  complement to "252" proc - Wideband?
 OBD1   219   JDM      PR3-J51      92-93 Integra XSi B16A  no inj test, no PA, yes knock
 OBD1   223   JDM      P27-T50      SOHC
 OBD1   224   JDM      P07-T50      SOHC Vtec-E
 OBD1   229   USDM      P06         Civic DX D15B SOHC      auto
 OBD1   230   USDM      P28         D16Z6 SOHC         manual (but isn't #230 an OBD0 PM5 ? - DaveJohnson)
 OBD1   231   USDM      P05         Civic CX D15B8 SOHC      1 wire O2 link
 OBD1   232   USDM      P75         Integra B18B GS DOHC      (Also PR4) link
 OBD1   235   OzDM      PR4-Q61      Integra B18A GS DOHC
 OBD1   236   Brazil      P30-G00      EG6 B16A2 DOHC Vtec
 OBD1   237   JDM      P08-001      D15B SOHC Vtec
 OBD1   238   ?      P04-G00      D15B2 SOHC
 OBD1   240   JDM      P30-J00      Civic B16A DOHC Vtec      (square ECU)
 OBD1   243   JDM      P08-010/911      D15B SOHC Vtec
 OBD1   244   OzDM      P29-Q01      Civic D16A ZC DOHC      OBD1 ZC
 OBD1   245   JDM      P30         Civic B16A DOHC Vtec      (square ECU)
 OBD1   246   JDM      P30-901      ECU B16 DOHC Vtec      auto
 OBD0   248   USDM      P09-A00      Civic DX D15B7 SOHC
 OBD1   248   USDM      P05-L01      Civic CX D15B7 SOHC   1 wire o2
 OBD1   249   USDM      P05         Civic D16B7 SOHC   1wire o2
 OBD1   250   ?
 OBD1   251   USDM      P28-A01      Civic EX D16Z6 SOHC Vtec   auto
 OBD1   252   JDM      P07-G01      Civic SOHC Vtec-E 1500   (2nd CPU)
 OBD1   253   JDM      P91-900      Civic EJ1 Coupe D16Z SOHC Vtec
 OBD1   254   EDM      P28-G01/G51      Civic SOHC D16Z6 Vtec
 OBD1   267   ?
 OBD1   269   JDM      P72         Integra B18C4 DOHC Vtec
 OBD1   270   JDM      P75         Integra Integra B18B Esi DOHC
 OBD1   273   USDM      P72         Integra B18C1-3 DOHC Vtec
 OBD1   274   USDM      P75         Integra B18B LS DOHC
 OBD1   283   JDM      P08-N01      D15B SOHC Vtec
 OBD1   300   USDM      P05         Civic CX SOHC D15 (94-95)
 OBD1   301   USDM/CDN  P06-A02      Civic DX D15B7 SOHC
 OBD1   303   USDM      P07         Civic VX D15Z1 SOHC Vtec
 OBD1   304   USDM      P28         Civic EX D16Z SOHC Vtec
 OBD1   305   USDM      P30         Civic/Delsol B16A DOHC Vtec
 OBD1   306   JDM      P08-N01      D15B SOHC vtec
 OBD1   309   JDM      P91-901      92-95 Civic Coupe (sohc vtec 1.6)
 OBD1   312   JDM      P30-901      Civic B16A DOHC Vtec    Automatic
 OBD1   314   OzDM      P06-Q00/Q50      Civic D15B SOHC
 OBD1   315   OzDM      P28-Q50      Civic D16Z SOHC Vtec
 OBD1   317   EDM      P28-G02      Delsol D16Z6 SOHC Vtec '94
 OBD1   318   JDM/Exp.   P30G         Civic B16A DOHC Vtec
 OBD2A   320   OzDM      P2P-Q01      96-98 Civic Ex D16Y8      MT, 66507, board M1Y-C 014T-L5000-01 1st gen immo, KS, no PA
 OBD1   327   US/JDM      P28         Civic D16Z SOHC Vtec      auto w/datalogging
 OBD1   332   USDM      P75         Integra B18B GS DOHC
 OBD2A   339   JDM      P72-013      Integra B18C         MT, 66507, board M1Y-C 014T-L5000-01 KS, no PA
 OBD2A   341   OzDM      P75-Q02      Integra GS B18B     MT, 66507, board M1Y-C 014T-L5000-01 no PA, no immo, no KS
 OBD2A   357   OzDM      P72-Q13      Integra B18C         MT, 66507, board M1Y-C 014T-L5000-01 immo, KS, no PA
 OBD2A   361   JDM      P2T-J91      99-00 Civic Si B16A3      MT, 66507, board M1Y-C 014T-L5000-01 no PA, no immo, KS
 OBD2A   388   OzDM      P2M-Q61      98 Civic D16Y      AT, 66507 M1Y-C 014T-L5000-11 no PA, immo, KS
 OBD2A   484   OzDM      P2M-Q01      98 Civic D16Y      MT, 66507 M1Y-C 014T-L5000-01 no PA, immo, KS
 OBD2A   493   USDM      P2P-A33      96-98 Civic Ex D16Y8      MT, 66507, board M1Y-C 014T-L5000-01 Has provision for immobilizer but not present
 OBD3?   515   OzDM      PND-Q51      Integra   66592 PA
 OBD2A   526   OzDM      P5M-Q01/Q51      97-01 Prelude H22a      MT/AT, 66p509, board E2Y-B 0014F-L5000-0, KS, immo, PA
 OBD2A   527   OzDM      P5L-Q51      97-01 Prelude      MT/AT, 66p509, board E2Y-B 0014F-L5000-0, immo, PA
 OBD3   686   OzDM      PPA-Q53      CRV 2002 K24         66Q592 PA, immo?
 OBD2A   700   OzDM      P3F-Q01      ?            MT, 66507, board M1Y-C 014T-L5000-01 no PA, immo, no KS
 OBD2A   715   EDM      P73-G01      ITR B18C6         MT, 66507, board M1Y-C 014T-L5000-01 no PA, immo, KS
 OBD0   717   OzDM      PP4-Q020      88-89 Concerto
 OBD2A   796   OzDM      P73-Q01      ITR B18C7         MT, 66507, board M1Y-C 014T-L5000-01 no PA, immo, KS
 OBD2A   836   OzDM      PEA-Q50      Odessey 96 F22B      KS, PA, 2nd gen immo
 OBD2B   866   OzDM      P2T-Q12      99-00 Civic Si B16A3      MT, 66589, board M2Y-D 0016Z-L5004-A0 2nd gen immo, KS, no PA
 OBD2B   933   USDM      P2T-A11      99-00 Civic Si B16A3      MT, 66589, board M2Y-D 0016Z-L5004-A0 Provision for immobilizer?   binmugen
 OBD1   952   OzDM      P75-Q51      95 Integra B18A      AT NEC B5J-D 2D190-1501
Zdroj: www.pgmfi.org
Vìtšinu BIN obrazù je možné stáhnout z www.pgmfi.org.
[/url]
Postby dohcvtec » Sun Mar 05, 2006 1:59 pm
if you can register to forum.pgmfi.org, you can visit this link:
http://forum.pgmfi.org/viewtopic.php?t=8086
this is an effort to flash the Accord 2005, which is the same hardware platform as other 2005+ honda/acura ecu's.
id like to contribute on any way possible, since i happen to own a 2005 Acura TSX which needs a reflash if that way is found. :D
dohcvtec
on the board above in the pic
Postby jak » Sun Mar 19, 2006 10:22 pm
I see what looks like a 10 pin BDM location?
you may be able to solder a 10 pin BDM header onto that bad boy
I could be rong Id like to see one myself
what is that ECU from specifically?
JAK
jak
Postby qoncept » Mon Mar 20, 2006 6:38 am
jak, that's from a 2002 RSX Type S. I'd really like to avoid having to solder chips on it -- OBD-II says you don't need to do that.
