Disable rear o2 CEL on A4SGC00C ECU?
Postby gethin » Thu Feb 16, 2006 11:10 am
Greetings,
I have the A4SGC00C MY02 WRX ECU and I am trying to dig up the correct location to disable the rear o2 CEL, as I am going to run a LM1 wideband with Bosch sensor and remove the OEM o2.
I have posted my ROM in the USDM 02 collection if anyone wants to help!
Here's where I have found the relevant o2 codes :-
P0037 - Rear O2 Sensor Heater Control Circuit Low **
0x00002EBC
0x00007D2C
0x00007DEA
0x00007DF6
0x0002DBB5
P0038 - Rear 02 Sensor Heater Control Circuit High **
0x0002DBAD
P0137 - Rear O2 Sensor Low Voltage **
0x0001E7B4
P0138 - Rear O2 Sensor High Voltage **
did not find this
P0139 - Rear O2 Sensor Circuit Slow Response **
0x0002DAF1
Which one do I overwrite with the 05 00 00 sequence? Or do I disable all of them for the rear o2? Which one is the correct location for the P0037 as I found 5 locations?
Any help appreciated as my wideband is being delivered today or tomorrow!
Thanks,
Gethin.
gethin
Postby cboles » Thu Feb 16, 2006 11:25 am
only the 0x2Dnnn ones are correct. everything else is just coincidence.
Postby gethin » Thu Feb 16, 2006 12:43 pm
Thanks colby, so these are the correct ones to overwrite then
0x0002DBB5
0x0002DBAD
0x0002DAF1
gethin
Here's my modded ROM file
Postby gethin » Thu Feb 16, 2006 10:30 pm
If anyone cares to check it before I go and nuke my ECU tomorrow!
:D
Gethin.
2002gethin_192_rear_o2_celfix.rar
A4SGC00C + rear o2 CEL fix
(79.42 KiB) Downloaded 438 times
gethin
Re: Here's my modded ROM file
Postby ride5000 » Thu Mar 09, 2006 8:34 am
gethin wrote:If anyone cares to check it before I go and nuke my ECU tomorrow!
:D
Gethin.
how did it go?
-ken
ride5000
Postby gethin » Fri Mar 10, 2006 10:11 pm
Hey Ken,
I've not tested yet, been busy with other things, and I had stuck the stock o2 is back on the car as the used LM1 I bought from a NASIOCer was faulty, bad serial port. Innovate repaired it FOC and sent it back, arrived today! Weee....so tomorrow I will be swapping in the W/B o2 again and I will test flash my modifed ROM to see if the CEL does not appear.
Will update the thread tomorrow.
Gethin.
gethin
Postby gethin » Sat Mar 11, 2006 1:03 pm
started another thread by mistake instead of replying to this one
http://forums.openecu.org/viewtopic.php?t=360
gethin
