Help requested for 2005 Australian RHD Impreza 2.5 RS 4EAT
Postby Ominence » Fri Jan 20, 2012 1:16 am
Hi all,
Just got my new OP2 and tried interfacing with the green test mode connectors connected. Car entered test mode with flashing CEL and cycling radiator fans.
Please help in getting this to work on my non turbo Impreza.
I am sure that I am not missing any steps. I was unable to find the 2nd set of connectors on the passenger side. Picture of the jumper block also attached along with ECU cover label and the log file.
Thanks.
Full page print.pdf
(919.63 KiB) Downloaded 1028 times
Ominence
Re: Help requested for 2005 Australian RHD Impreza 2.5 RS 4E
Postby radsdau » Sun Jan 22, 2012 2:59 pm
Non-turbo Impreza? Check if the ECU is JECS or Denso. Only Denso ECUs are supported with ECUFlash.
Postby Ominence » Sun Jan 22, 2012 7:23 pm
Hi radsdau,
I am running a supercharger and there is a Moristech Prosequential piggyback ECU in the midst. I have tried by completely disconnecting the piggyback as well.
How do I identify which ECU it is based on... any tips??
Thanks.
Ominence
Postby Sasha_A80 » Sun Jan 22, 2012 7:50 pm
This is JECS\Hitachi ecu for probably EJ254 engine.
If there is JECS WA12212940\12212970 processor inside this ecu is currently not supported.
Sasha_A80
Postby Ominence » Sun Jan 22, 2012 8:35 pm
Hi Sasha_A80,
It is an EJ251 4V SOHC, no variable timing or lift.
I haven't opened up the ECU yet, and may do so if there is no other way to identify it??
Thanks.
Ominence
Postby Sasha_A80 » Sun Jan 22, 2012 11:03 pm
JECS ecu for EJ251 is usually based on 12212920/12212930 chip that is prone to fail during reflash.
More recent Hitachi ecu is based on 12212970 that may be reflashed in a safe manner.
But. There was no motivation for this development.
Probably you are to contact mmcflash developers.
Sasha_A80
Postby Ominence » Mon Jan 23, 2012 1:44 am
Thanks Sasha_80,
......Its WA12212920WWW as per attached.
So ...is there anything we can do?? You have been been very helpful.
Any recommendations for a flashable, compatible replacement ECU? Any other known methods of flashing this?
Thanks.
Ominence
Postby Sasha_A80 » Mon Jan 23, 2012 3:25 am
It is strange to see JECS MY99/00 ecu inside the car referred to as MY05 Australian.
Try to get ECUID by LearningView for example. Probably I may provide an appropriate ROM image.
I would not recommend to try to reflash this ecu if you do not have a couple of spare ones.
From the other hand there is Arabic MY04/MY07 (??) ecu for EJ202 (that is almost identical to EJ201) that is based on 12212970.
The last may be reflashed safely.
But. There is immo and a number of checksums inside the code.
European\Japan EJ202/EJ152 ecu's are completely another animals and are based on Reneasa SuperH.
Sasha_A80
Postby Ominence » Mon Jan 23, 2012 4:23 am
Thanks Sasha_A80
I do not have any spares. I have no idea why it would have this old an ECU in it. Car is built April/05.
LearningView ECU ID same as ECUFlash ECU ID- 3D52103005
Where to get these different ECUs from? any recommendations? I am guessing you are suggesting that these are not fully compatible. As long as ABS, cruise and climate control and auto tranny work- it will be fine by me.
Thanks.
Ominence
Postby Ominence » Mon Jan 23, 2012 4:34 am
Because Learning View says
'ECU ID of 3D52103005 not found. Your ECU is not currently supported.'
Maybe that means ECU ID is actually unknown?? I don't know then what 3D52103005 means.
Ominence
Postby Sasha_A80 » Mon Jan 23, 2012 4:48 am
It is really updated ROM image. MY99/00 ECUID started with 0D, 1D.
But PCB and processor chip is obsolete.
This ecu hardware does not support CANbus thus ABS should be linked to auto tranny, that in turn "speeks" to this engine ecu.
It gives a chance to find European\USA setup with more recent engine ecu coupled with the same TCU. This is just my opinion.
This gives a chance to reflash 12212970 based ecu.
Sasha_A80
Postby Ominence » Mon Jan 23, 2012 5:09 am
Many thanks Sasha_A80
so... any recommendations for further actions?? How do I find 970 based ECU which works with my car?? The TCU is a little harder to get to under the steering column.
Ominence
