Hi...I'm basically new to this ecuflash thing...I have issues when I view all my map and I am not sure what to do next As if ecuflash is reading all the wrong address from the xml file. I'm hoping all the seniors could advice what to do. You can see the sample for the High octane fuel map below which is totally different from stock ecu map.
FYI - I'm using an Evo 9, AUDM ,year 2006
Thank you in ad.vance.
