XML for 2006 Lancer Ralliart 2.4L
Postby CorrPerformance » Fri Jan 28, 2011 11:08 am
I been reading countless thread trying to find the definitions for this car with no luck. I need it so I can tune one of my clients vehicle and it pains me to start a thread if somewhere the definition can be found for this vehicle.
Here I send the link to the HEX/BIN file
http://www.box.net/shared/k2i0maxjro
Thanks in advance to whomever is able to help me out in this dire situation.
Alberto
CorrPerformance
Re: XML for 2006 Lancer Ralliart 2.4L
Postby CorrPerformance » Sun Jan 30, 2011 6:31 am
Let me know if any one has downloaded the file and started looking at it. Thanks!
CorrPerformance
Postby Mitsiman » Sun Jan 30, 2011 8:23 pm
The software is currently unable to flash this model ECU its not workign properly, which is also why there is no working definition file yet.
Mitsiman
Postby CorrPerformance » Mon Jan 31, 2011 8:08 am
Correct, I updated to the latest ecuflash version and downloaded all the definitions on this model that I could find and still nothing. The client was telling me that this model was being flashed on puerto rico. Dont know how true is that. Any way now my issue is this, need to make some changes to a evolution 8 rom on tephra and when I try to open that rom, the ecuflash crashes. I have release the tephra definitions to the rom data folder and no success. Any recommendations?
CorrPerformance
Postby Mitsiman » Wed Feb 02, 2011 12:10 am
If its crashing you have a conflict with your defintiion files. or you are using a definiton file that is looking for some coding that isn't there.
Mitsiman
Postby CorrPerformance » Wed Feb 02, 2011 6:29 am
Would uninstalling this version and dropping down to the previous version fix the issue? Of course with loading the Tephra defintions that were there before.
Thanks for the reply Mitsuman
CorrPerformance
Postby todd-w » Fri Feb 04, 2011 4:57 am
corrupt def file will cause that too remove the last xml you put in or edited and try then
todd-w
Postby CorrPerformance » Fri Feb 04, 2011 6:01 am
Thanks, Todd-w will try that and let you know what happens.
CorrPerformance
Postby CorrPerformance » Mon Feb 21, 2011 5:09 am
I installed the version I had previously in a different Folder, put the tephra definitions back in the ROM folder and it worked.
On saturday I had to reflash a Evo 8 and the latest version of EcuFlash and the 2.0 tactric cable and would not work well with the Evo 8 I had at the shop. I opened the version 1.42.2595 took out my 1.3 cable (had a spare one) and all worked accordingly. So dont know what is going on with the Evo 8 and the new version of EcuFlash since on a 2009 Ralliart i was working with the 2.0 cable and new version of the software with no issues.
CorrPerformance
Postby CorrPerformance » Mon Feb 21, 2011 5:16 am
There is a guy by the name of Hackish that is flashing these ecus. So it is possible.
http://www.youtube.com/watch?v=UcYt-GFyBhE&NR=1
http://www.youtube.com/watch?v=JhJdNsc-sWc
So there are methods of doing this reflash to this engine. Interesting.
CorrPerformance
